ok cut a long story short.
rb25det 350rwhp 20psi kkr480 turbo done 50,000kms or so since new.
ive been running no bov for pretty much the whole 50,000kms.
ive notice last few months if i bring it on boost 20psi and as soon as i back off it will dump some oil out the rear, wont do it driving normally or idling.. just after a big compressor surge ...
if fitted up a greddy bov just before throttle body. anyway basically its stoped the oil dump after a big decel from what i could see atleast.
could the compressor surge be causing the oil 2 get past the seals and out the exhaust?
i hate bov's i really really do..id rather not run one.. car seems 2 come on alot harder/better without any bov..
i just get fu k ed off with the oil smoke after a i get into it. embarrasing haha.
any ideas? or could it be my motor?
Edited by l0WRB
https://www.sau.com.au/forums/topic/295099-turbo-or-motor/
If you have in and out shaft play then it is the turbo. Or check oil drain pipe make sure its not kinked and engine is not over filled.
engine is not over full, only done oil change 200kms ago.
oil return line isnt kinked either.
took 4 a spin just before tightened the bov right up.
20psi right under it and backoff it dropped a puff of oil smoke hrmm
https://www.sau.com.au/forums/topic/295099-turbo-or-motor/#findComment-4922217
Could it be the PCV or crank case breather? Are you running a catch can?
There is a lot of manifold vacuum at close of throttle, it could be related to that.
PCV isnt hooked up
breathers are running back into the intake pipe.
https://www.sau.com.au/forums/topic/295099-turbo-or-motor/#findComment-4922265
PCV isnt hooked up
Get a catch can on it. My RB25/30 was dumping alot of oil out the breathers on back off on the dyno...
Also found it severly breathing oil on the track though too...
https://www.sau.com.au/forums/topic/295099-turbo-or-motor/#findComment-4922362
yes mine also breaths heavy after a good thrashing or on dyno..
mite get a bit of oil in intake and front cover of turbo after 5000kms and hard thrashing
mite try just venting the breather with a filter.
just the smell annoys me smelling it breathe
https://www.sau.com.au/forums/topic/295099-turbo-or-motor/#findComment-4922466
Put a catch can on, and plumb it all in properly.
This is what they're for!
https://www.sau.com.au/forums/topic/295099-turbo-or-motor/#findComment-4922523
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
