Am boring with the color, but still love the style. So I'm just wondering where can I have my wheels be re-paint and what price mark should I looking for? Better be in northen suburbs but willing to travel a little bit.
By the way, the wheels are 18', and how long should the re-paint takes? Thanks.
https://www.sau.com.au/forums/topic/295142-where-to-re-paint-wheels-in-melb/
Good question:
I am looking for options with this as well. I reckon the premium option is Mick @ Micolour, who will do the best job you're likely to get.
Vu @ DT said to me over the phone that he doesn't paint wheels.
Any cheaper options anybody?
Craig @ Colour Ur Mags or Rims, can never remember which.
Avoid the big players in Moorabbin, rip off central.
Craig is a bit eccentric, and it looks like you dropping your rims off in some back yard workshop, but the quality is great and at a very reasonable price point. Had my 34 R rims power coated, but he can paint as well.
Powder Coating:
Reefies Paintworks
53 Amberley Crs, Dandenong, VIC 3175
p: (03) 97931611
They prob paint too. Shakiels dads biz, Shakiels mobile number can be found here: http://www.feeninperformance.com.au/
Make that two... I felt ripped off by the Moorabbin big wheel repair shop... $160 or $180 and 1 month later the wheel just peel off...
I mean WTF...\\\
and here I am now still looking for a reliable wheel repair shop in the west or inner city ....
as the wheel is on the car it's hard for me to find time to have the wheel off the car for a week or two...
Powder Coating:
Reefies Paintworks
p: (03) 97931611
yeah these guys are good, had my old rims pwder coated there
Powdercoating is the way to go...it lasts a long time if done properly. I had a set of scratched up, painted black S15 wheels that I got powdercoated in silver and they looked factory brand new. Awesome work. Some joint in Bayswater...there's a couple there who do powdercoating.
Bayswater Powder Coating
F1/12 Melrich Road, Bayswater, VIC 3153
p: (03) 9762 4991
They can strip, blast and powdercoat your wheels.
Strip - $30 per wheel
Blast - $30 per wheel
Powdercoat - $30 per wheel
OR
$100 at smooth performance in bayswater (all 4)
speak to ray 0407 824 957
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
