Hi guys,
Bit of a noob question here but i dont know much about suspension. I recently aquired my 1998 r34 GT-T, and it is on bilstein shocks and king springs and is very low -the body kit hangs down crazily low especially the front guard. So low in fact that i would like to raise it as to be honest it would still look good a bit higher, and wouldnt be pretty much impossible to park anywhere through a driveway / go over any bump. Is there any way i can get it raised without spending like 2k on coilovers etc?
thanks, Sam
https://www.sau.com.au/forums/topic/295143-suspension-question/
Buy new springs. You can get custom wound springs to any height you want, and if I remember correctly they go for around $250-300. Otherwise, there have to be off-the-shelf items that list their "height drop from stock" values, and find one with a mild drop. Look at a stock R34 and decide how much lower you want your car sitting compared to theirs.
Make sure the dampers aren't dead while they're out, as worn dampers will also have the car sag a bit.
Bilsteins usually have several grooves machined into the main body. The groove retains a circlip which supports the spring platform. Check that the units haven't been assembled with the circlip on the highest groove. You could also get new grooves machined to raise the spring platform.
Don't quote me on it, but I heard that was the going rate from somewhere.
ModYourCar has King Springs at $166 a pair for R34 springs.
$332 isn't that bad. You can do your own research off that link to find out how much the lower and superlow springs are from them. I'd suggest contacting King Springs directly if you want something custom made.
JustJap sells BC Racing coilovers, which are rate and height adjustable, for $1300 new. I have no idea how the ride or handling is with them, but the cost isn't that great.
update - i had the front bumper tightened as it was slightly loose (and it actually ended up about 3mm higher off the ground all round) anyway today i got over a speed bump =D haha (one of the black and yellow, like flat top pyramid ones) so perhaps i can get away with not raising it.
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
