So,
Thought I'd start a thread for two reasons, show what you have and give info and tips to others looking to buy race gear for the right racing!
So,
What does everyone have?
I have a mixture - Ive got an RPM suit, ERG gloves and looking to buy shoes to do MRA
My helmet was given to my from my best mate for my 21st - still going strong today!!
https://www.sau.com.au/forums/topic/295177-the-racing-apparel-thread/
I have a Shoei helmet :rofl:
I am also looking into buying a suit, gloves, boots etc, So i will be interested to see what the pick of the bunch are.
I have been looking at the RPM single layer club sprint package that revolution offers, anyone using this now?
Thats what mine is Ryan. Ando and I use them.
You'll need to by the underwear also for doing MRA AFAIK, but have also been told can wear long pants and long sleeved shirt underneath also.
Can't let Chris have the goofiest pic in this thread :thumbsup:
My gear bag now contains:
Stilo helmet and a HANS device - sports version (the poor mans version) but just as good as its big brother
2nd helmet which is now my back up for if I ever can't run in my Stilo & so old I can't see or remember the brand!
RPM Mondial suit (double layer)
ERG Protek suit (double layer)- second suit a good investment for me given how smelly they can get after sitting in them for days at Targa!
Sabelt balaclava & fire proof undies. Sabelt had the only black balaclavas I could find- they don't show the grime you pick up after dropping them on the floor!
OMP Gloves
Co-Pilote Rally Watch (does superduper rally stuff & is definitely smarter than me)
Will post some pics when I am awake enough to hold a camera straight (tired, not pissed before you smartarses say anything!)
Below is my first investment in gear, purchased with a gift voucher from mates (hence the dodgy pic to show what I'd bought!).
These are still my favourite dancing boots- made by ERG and are super comfortable and a good fit for a smaller foot. Can't remember the style but ERG don't seem to make anything like them now. Unfortunately they stopped being the right standard for rallies run under CAMS so I also now own a pair of Sabelts which are not nearly as good a fit.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
