599s and 612s are the F cars I am most cautious of on the track as they go well in a straight line but are such terrible handlers and the traction control so intrusive they almost grind to a stop mid-corner. You need to be very carefully lined up in the 35 so that you dont run into the back of them on corner exit as that certainly would be an expensive mess. 360s are generally too slow to mix it with most of the stock GTRs we have on track days so dont really spend much time in their vicinity on the track. F355 and older are generally roadblocks that ruin everyones day. No hating, just generally find them annoying to the faster guys that want to get some track time in :(
Edited by Martin Donnon
  • Replies 280
Posted Images
599s and 612s are the F cars I am most cautious of on the track as they go well in a straight line but are such terrible handlers and the traction control so intrusive they almost grind to a stop mid-corner. You need to be very carefully lined up in the 35 so that you dont run into the back of them on corner exit as that certainly would be an expensive mess. 360s are generally too slow to mix it with most of the stock GTRs we have on track days so dont really spend much time in their vicinity on the track. F355 and older are generally roadblocks that ruin everyones day. No hating, just generally find them annoying to the faster guys that want to get some track time in :)
Haha man, R35 GTRs are roadblocks when im in my Radical :(
Would be cool if one could drive them on the road......but if I was in the market for a track car I would get a Lotus 2 eleven before a Radical.....(still love the radical but...)
http://www.diseno-art.com/encyclopedia/veh..._track_car.html
Martin, Martin, Martin.
I see you are still sore since my Ferrari lapped your Ferrari on lap 81 at Mallala the other day.
You have been most radical at attacking these fine gentlemen who like to drive their Ferraris as hard as they did when they were 17 ;)
You have been most radical at attacking these fine gentlemen who like to drive their Ferraris as hard as they did when they were 17 :laugh:
what did Vin Diesel say in the original Fast and the Furious???? inch or a mile.......
Methinks you would need some very good throttle control to use the short rev range of an LS engine in an open top club car. Traction wise, it just makes sense for them to have a buzzbox engine...
F355, F360 are POS. Italian trash IMHO. If only Ferrari can make their road cars half reliable as their F1 cars, then I will respect them more.
Like a one night stand with a hot blonde, the F355 and F360 are not the cars you want to keep long. Got friends who HAD owned them and they are more trouble than what they're worth, and believe me, they bring a new definition to the terms 'fragile', 'temperamental' and 'overpriced'.
Apart from the 'pose' factor, I can't see why anyone with half a brain and half the logic of a normal person would ever want to choose a F360 over a new GTR.
Edited by skyline_man
beacause as I said before, if you can afford one, you can afford both.... I'f you can't afford both you really can't afford to maintain either cars and your better off not wasting your money if you have to borrow on expensive cars...
Are you for real? Even if you can afford both, why would you? The GTR can do everything that the 360 can and even more. So why would you fork out 160k odd for a second hand car that will spend more time in the workshop getting repaired than it does on the road? Why would you spend 160k for a "supercar" that can't even beat a new STi or Evo?
I tell you why. It's because you're a POSER and you want the majority of people (who knows nothing about cars) to look at you and say...."ooohhhh, he's got a Ferrari"
All this talk and love of F360's makes me sick. Any of you fan boys ever had anything to do with them? Seen how fragile and poorly built they are? Seen how BLOODY SLOW they are when on a track? They're pathetic, and are simply a prosthetic extension for short balding men.
There is no contest between one and a 35, but personally, I have no aspiration to own either. The 35 is too smart by half for it's own good, they drive me nuts. GT3 for me :)
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
