Hey guys i am looking for 10K or another car pref (AUTO) as i am sick of manual in city driving.
Would love to swap for something like a stagea or a V8 stato or something else automatic and still a bit gutsy. Something cheaper with cash adjustment is fine too (open to all trades)
Below are the specs on my vehicle
-1992 R32 GTS-T
-To4e turbo
-Turbosmart pro gate 45 external wastegate
-Big front mount intercooler
-Remapped ECU tuned by Geoff from speedlab
-Full 3 inch exhaust system
-KAAZ 2 way LSD
-Drift pineapples
-Adjustable castor rods
-Tein coilovers all the way around
-Apexi front and rear strut braces
-K&N custom catch can
-BOSCH 040 Fuel Pump
-Blitz boost controller
-Greddy turbo timer
-Solid gearbox mounts
-Autometer ultra light pro comp boost gauge
-GTR front bar with new lip
-Genuine nardi steering wheel
-Trust gearstick knob
-Paint is half decent but not perfect (resprayed GTR red)
-Everything works perfectly inside and outside of the car
-Cold A.C no broken vents
-Top of the line viper alarm with remote central locking and AUX feature that closes the windows if left open :cool:
- GO KART SPEC :)
Probably lots more that i have forgotten about I have thousands of dollars worth in receipts.
Car is registered and located in Adelaide
Contact me on 0423337520 or send me a PM
****NOTE RIMS NOT INCLUDED IT IS ON STOCK RIMS**** ****NOTE RIMS NOT INCLUDED IT IS ON STOCK RIMS****
didn't take long matt... not even a week....
:blush: Yeah After the stato and xr6 turbo being auto now in to this makes me realize how much i took for granted driving an auto and using cruise control etc. Call me a Nancy all you like hehe and then trade me :)
bump so i can find this easyer.
hope finance is all good and can find another car for kate and the bub. so keen on this.
:P :P
BUMP! - For 10K "CASH" price i will chuck in the stereo installed JVC dvd head unit with 3" screen - JL Audio Splits - Jensons rears - Type R alpine 12" sub - kenwood 4 channel amp and BRAND NEW sony 4 channel with receipt. - Not included with swaps
Some more pics
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
