I'm after a carbon fibre bonnet, just for looks, i have heard they are illegal because carbon fibre is weaker then a standard bonnet meterial, meaning if you were in an accident it would shatter not crumpel, a good mate of mine (signwriter) came to me and said he could put a carbon fibre vinyl cover (sticker) over the original bonnet, said it would look exactly the same, cheaper then all the hastle of getting an actual carbon fibre bonnet including price, shipment of something that size etc.., also this making it completely legal.
only problem is i dont want to be seen as 'fake'
opinions?
https://www.sau.com.au/forums/topic/295206-vinyl-carbon-fibre-bonnet/
EPIC FAIL there is no such thing as a carbon fibre vinyl and it will definatly not look anything like carbon fibre it will look like a stick on fake carbon fibre wich if you like the ricer look and thats what you want to achieve it will be an absoloute success. If you dont want a genuine carbon bonnet just go without in my opinion, But hey each to their own if we all liked the same thing there wouldn't be enough to go around.
Edited by dazmo
lol, oh well i guess thats off my to do list.
i do have to say tho, first google search i tried i found this
http://www.gammods.com.au/store/index.php?...;products_id=47
but your right, thats why i posted this to see what people think, havent really heard of it being done before.
Edited by azzafreddy
Aaron, there is no reason why it can't look good and realistic, firstly, getting it done by a pro will ensure a good job, there are plenty of convincing and very nice looking carbon fibre vinyls around. Further more you can clear coat it in a gloss or a matte clear finish so it isn't too shiny.
Have a bit more of a look if you really do want the cf look without the illegality, its not such a bad option
http://www.youtube.com/watch?v=0VMVjRSMgik...feature=related
Each to their own, its a styling mod that some will like and others wont, but i think if you like it, don't worry about what others think.
yeah, thats what i thought as well, i have a friend who is nearly 10 years in the trade, since finishing his apprenticeship, so i could get him to do it easily, i can absolutely respect what people say about it being fake and not genuine, because im also a big believer in doing things properly.. i would myself rather have a genuine carbon fibre bonnet shipped to my house and installed, just dont want to run the risk of getting defected for having something illegal on the car, its not worth it, even tho cops would barley know the difference you would always get your 1 or 2 who do there job really well.. so for now i dont think ill worry about it just wait till something else comes along, might even decide to get a carbon fibre bonnet and risk it, just keep the origional one in the shed.
Why risk it? Just get an ADR approved hood and you'll be fine.
As for the vinyl - like on the GTR posted above... it looks for for accents, but as for a whole panel... It might or might not. Imagine if you yourself don't like it once you've paid for it :down:
I did a carbon fiber headliner recently for my Sentra. Turned out all right and didn't cost that much. Sure you could do the same thing to a metal hood if it was just for looks.
stripped off the cloth
rubbed off the foam
laid down a sheet of single weave carbon fiber and coated with epoxy resin
Here's a close up of the weave after the epoxy dried. I'll take a picture of the installed headliner tomorrow. This was my first project using carbon fiber. With a little more practice I'd like to start making things like intake and brake ducts.
Amazing, most people start with the small stuff and work their way up, Guessing yours are made of solid Steel!
I'm considering doing some parts too. Covering looks simple enough.
Search Google for vacuum bagging carbon fibre technique. You use plastic to vacuum hold your object to the shape. This forces the carbon weave to sit flush without as many ripples.
Of course you need something small enough to cover in plastic and hold vacuum while it cures.
As for the vinyl - like on the GTR posted above... it looks for for accents, but as for a whole panel... It might or might not. Imagine if you yourself don't like it once you've paid for it ;)
proper look alike CF vinal is top quality and if you did a whole gtr bonnet it would probably be close to same weight and would look good, its just getting a sheet of vinal that big to cover the bonnet, it would be quite easy, like laying decals.
  • 3 weeks later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
