A quick list of mods to be used to get up and over 250kw at the wheels
Add in labour costs, fluids, and dyno tunes
Engine: - $11,500
$30 - Ryco Z201 fuel filter, Ryco Z145 oil filter
$200 - Bosch 040 fuel pump with direct battery feed at 13.8volts
$500 - Splitfire coil packs
$20 - NGK BCPRE6 0.8mm copper v-groove spark plugs
$150 - Davies Craig automatic transmission oil cooler upgrade kit
$470 - MV Automatic valve body shift kit & auto service kit
$500 - Koyo Radiator upgrade
$150 - Greddy remote oil filter relocation kit
$20 - Fujimoto sump plug drain valve
$60 - Catch can kit
$150 - Nismo adjustable fuel pressure regulator
$250 - Nismo Z32 Air Flow Meter
$230 - 3inch JustJap stainless steel single dump pipe system
$250 - 3inch high-flow metal race cat
$300 - 3inch cat-back exhaust system with Magnaflow mid-muffler and Kakimoto GTR Racing rear-muffler
$100 - Cold Air Radiator air guide for cold air induction
$100 - Apexi power intake pod filter, using standard snorkel air feed & under body feed
$600 - Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
$100 - Hard pipe intake to turbo
$100 - HKS heavy duty turbo actuator
$2500 - Garrett GT3076 700177-5015 IWBB Turbocharger, ported Nissan 45V4 front / AVO .73 rear housing
$500 - JDM S15 Silvia 450/480cc injectors
$120 - ARP head stud kit
$2000 - Ported, Flowed & Machined headwork including new valve seals, valve seats and valve guides
$200 - EPP Clear camgear timing cover
$200 - Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
$250 - Cometic head gasket 87mm x1.2mm
$100 - Aerospeed adjustable exhaust cam gear pulley wheel
$900 - Tomei 256 intake / 256 exhaust poncam gear set
$400 - Tomei 8.8mm high lift springs
$50 - Tomei oil gallery restrictor
Suspension: - $3,500
$1300 - Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
$600 - Whiteline front and rear adjustable swaybars
$200 - Dayz adjustable engine swaybar, custom boot swaybar
$100 - Whiteline front castor kit
$100 - Whiteline rear subframe alignment kit
$1200 - Uwe Jean Ballou R32-GTR 17x9.5 inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes: - $2,000
$500 - Maltech stainless steel braided brake lines, front and rear
$400 - DBA slotted front brake discs
$100 - Cusco brake master cylinder clamp
$1000 - Panoz Outlaw 4000-series front billet aluminium 4-pot disc calipers w/ Wilwood racing pads
Interior: - $3,000
$300 - SAAS D1 Drift adjustable race seat
$200 - Flynn racing seat rail
$100 - Apexi electronic boost gauge
$200 - 3x 2" DIN gauge setup including boost pressure, oil pressure & oil temperature
$850 - AEM F/IC-8 copgyback ECU with Dell c640 latitude laptop
$350 - Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 1.00 bar and 1.20 bar
$1000 - Toshi ecu remap, tuned by Boostworx
250rwkw for roughly $20,000 in parts, plus servicing/labour costs - search ebay for savings
Don't do half that crap listed above. I can not believe someone wasted their time typing all that out. :)
Well lets see your opinion on what to do then :) No including 26 conversion and a 34gtr front end cos not all of us have mega coin to blow! Does look like the hottest stag in aus imo though mate :)
I'd be doing:
3" turbo back
Split Fires (if yours are missing AT ALL)
FMIC
EBC hi at 12 psi
Pod in a box with cold air feed and $5 intake pipe mod
SAFCII and SITC or as you have a S2 get the chip put on the board
Darrin is still running the RB25 Neo. To see 250rwkw and just above can be done on an unopened engine. basically what i will be running is:
- FMIC
- Ecu
- Fuel pump, not because the old one is dying but just for piece of mind
- Injectors
- Turbo upgrade, stock turbo would see 200 but not much more.
- Full 3" exhaust
- Air Filter with CAI
running a safe tune and boost level i hope to see between 220rwkw and 250rwkw. total cost for me, around the 5k mark.
Edited by QWK32
alot of the stuff listed has nothing to do with the power output though, so 20k for 250rwkw is a bit silly to write
rb25's are amazing motors, you don't need to spend alot to get them to 250rwkw - you don't even need to open them!
All that my Neo is getting:
Z32 afm + plug
Apexi PFC
Blitz 525cc injectors
Greddy Fmic
Blitz Nur front pipe + cat back
HKS intake pod
Alloy radiator
HKS GTRS/2535 or similar
Bosch intank pump
Should see over 220+awkw!
Edited by RED513
Z32 afm + plug
Apexi PFC
Greddy Fmic
HKS intake pod
Alloy radiator
Bosch intank pump
Assuming that your exhaust is 3in the main ingredient is a big turbo such as GT 3076 (or even a GCG highflow) and you should get over 240awkw. You could save money by getting a nistune instead of the PFC and spending the money on the turbo! (Oh and get a boost controller instead of the radiator).
- FMIC
- Ecu
- Injectors
- Full 3" exhaust
To get to the higher figure you may need an uprated afm.
Z32 afm + plug
Apexi PFC
Greddy Fmic
HKS intake pod
Alloy radiator
Bosch intank pump
Sounds literally exactly the same as a Neo engine I know :) My advice though, get the GTRS instead. The 2535 is great, but you'll end up wanting more :(
mate you can do it for 5grand
obviously my list is the whole thing, suspension,brakes,engine,electronics, 15k to 20k depending how you do it
it is a simple list & of course most parts arnt needed for power production - its not rocket science (ie braided brake lines wont net 1billionty kw)
why do I have to point that out? :(
haha sif you took that as a personal dig? but if you want to get technical, you did write:
Already got Pfc fitted and tuned, Injectors and Z32 awaiting bigger turbo!
Need a radiator as seeing 96'c and Qld summer coming up!
  • 4 years later...
Hi guys, Ive got a 99 Stagea RS Four S and im wanting to start building up an engine, ive found a 25det neo with 89,000kms for $2000. Just wondering what aftermarket parts i should get, nothing too expensive.
Cheers
I don't want to spend heaps, Don't really know what my budget is yet. just looking around 260kw mark atm. I wasnt meaning opening it up. Just external stuff
Edited by RBfreak69
FMIC, bigger injectors (480cc),new fuel pump, bigger turbo (hiflow), engine management (Nistune), 3" turbo back exhaust would be the most basic modifications required.
You can choose, bigger and better items but that is a basic starting point.
  • Like 1
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
