this is how i got my scopot bush out.lmao.pack the inside with grease and get a broom handle(or anything that will fit in there)and hit it with a hammer.just keep packing it and trying and it will come out mine took bout 10 mins .hope it helps
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
