Hi all,
Just wondering if anyone could shed some light. Situation is as so:-
1) New plugs gapped to 0.8mm
2) Cleaned and flow tested injectors - all ok
3) Fully rebuilt engine so no problems there (runs sensationally)
4) New fuel pump so plenty of fuel
Problem i'm having is that sometimes she sits and turns over for a little while rather than firing up. Could this be CAS or TPS (throttle position sensor)?
Cheers!
Dave
https://www.sau.com.au/forums/topic/29528-inconsistent-starting/
A lot of them do this, I'm not sure why. Mine goes through phases but other than that it runs perfectly so I just live with it. If it doesn't crank within a couple of seconds, I just stop cranking, wait 1-2 more seconds, then it fires up first kick. Because I know if it doesn't start within 2 seconds, it won't start within 5 :)
Also (could be related) the remote start on my alarm system doesn't always work, like it won't even attempt to start the car. Someone told me once that the CAS has to be in a certain range for it to work, so it'll only work roughly 1 in 10 times depending on where the engine's stopped.
If you have this problem then try my method of starting and see if it improves. If it works then there's probably nothing to worry about.
Edit: Hmm I just remembered Raist60 gave some advice on how to improve starting with a PowerFC setting, and I forgot to try it. I'll give it a go and see if it helps me, but that doesn't help for anyone with a stock ECU.
Hi all,
Cheers!
Dave
A common reason for cars needing to crank for a while before firing is either leaky injectors or a leaking fuel pressure regulator, i saw it on a r32 a few weeks ago with a hard start problem, but since you have a newly rebuilt engine it probably istn the problem.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
