Td06 17c V Vg30 On Rb20
Thanks everyone … will give it a go. Hope the added back pressure doesn’t screw up my weak rich idle issue I have… would be great if it helped it😃
Has anyone used 16 x 1.5 to - 6 orb to AN fittings on the pump? Are you still able to get the electrical connectors (chassis side) circled in the attached image and how could I the part numbers if so? I believe the pump I'm using is an R34 vspec/hydraulic locking rear. Thanks
Yes, just throw some gaskets at it and put it back in. As long as everything is actually designed to bolt up together it will all go back together. My CA compliant exhaust for example can only fit with the specific catback I gave them. -
By aligatorcat · Posted
Sorry I missed this. I ended up getting one locally. Appreciate your time to help. -
By thomasLait · Posted
Yes it is, the nm35 stagea has OBDII idk if the WC34 has it tho
