  • 1 month later...
FYI on the Z, I removed the rear bolts for the seat rails.
I slid a small piece of aluminium in there that had been drilled appropriately, and then affixed the fire extinguisher's bracket to that.
No photos, I'm afraid.
With the Z I don't have any rear passengers to inconvenience, but then adding/removing that aluminium mounting point would be a quick job.
A 1kg extinguisher is small enough so I can push the seat practically all the way back. I just move the seat forward on the track so I can easily reach the extinguisher.
Thanks Scathing.
I was going to do something very similar but the dimensions of the floor around the seat rails didnt allow for it.. at least not easily anyway.
My installation is far from ideal, but it works, and im in a hurry. It has to be removed post track day as its definitely in the way of rear passenger comfort.
The other thing I was considering, in a pinch, was temporarily mounting a 2kg extinguisher for track days rather than (or in addition to) the 1kg tank behind the passenger seat.
I'd use the front seat rail bolts, but then add a rectangular piece of metal (with an x in the middle for rigidity) to bring the mounting point forward so a 2kg will fit.
But, since I haven't tracked the car in a year while its had faults, I've had other things to do with my time. :(
Chuck up some pics for everyone else. :(
So I had some spare time to kill this morning. Decided to toy with the extinguisher mount in hope of ending up with something a little more sturdy and better looking.
This is where I ended up. Despite being attached to only one mounting point, it is very solid. I couldnt find anywhere in the CAMS manual that said it has to be attached to at least 2 points, so hopefully the scrutineers don't give me any grief tomorrow >_<
Is your fire extinguisher attached to something flammable?
yep :D just like the cotton clothing you have to wear & the seat materials
it passes for scutineering & that's all I need
happytimes
I couldnt find anywhere in the CAMS manual that said it has to be attached to at least 2 points, so hopefully the scrutineers don't give me any grief tomorrow :)
It does say in the CAMS manual that it has to be easily reachable from the driver's seat.
I'm a short-arse and I'd struggle to comfortably reach an extinguisher there (even with my belt off), so it'll probably depend on how anal the scrutineer is.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
