update. ok i've got that damn bolt off now, used a long pole for extension and it finally came off. the shock is still not coming off, i've sort of moved it half way out, not i can't get it out and can't get it back in. is there anything else i need to do?
thanks for the replys guys. didn't finish it in time, so drove my mums car to work :D
only have to put it all back in now, already changed the shock absorber. bit worried about getting it back in as i had enough trouble just trying to take it out! gonna have to try some of the tips suggested. for any beginners out there wanting to change the shocks urself, i advise you to read all the tips!
cheers
ok getting the shock back on the car is even harder than taking it off!
i was afraid of this, was so hard to get off, now its even harder to get it on. i need to compress it like 4cm to get it on.
i don't have a small enough jack to fit underneath there.
blind_elk can u give us a bit more info on ur idea?
thanks.
yep, i've tried pushing the axle down, it helps but still can't get it on!
my poor baby is currently offline until i can fit it back on!
btw, i have spring compressors, but u can't use them to fit the shock back onto the car as there is not enough room there for them. are u suppose to still clamp the springs and keep it on wen u fit the shock back on?
thanks
Jacks are the best way. If you don't have one, get yourself a trolley jack, they are really useful. Use it to put the car up on axle stands, then when it's on the stands, pull the jack out and use it to jack up the shocks. It's really easy once you do a few. Everytime you do them you just get naturally better at it and therefore quicker.
Hey JimX, i've tried to use the jack to jack up the shock, but theres really no room there for the jack. the axle etc are blocking the way to jack the shocks?
When you say trolley jack, u just mean the ones with wheels on it correct?
Sorry for the dumbass questions! This is VERY urgent atm as i've given up on it until someone has some new ideas which i can try. In the meantime i have no car :D
Theres no need to have the spring compressors on when u are putting the shocks back into the car right?
I'll upload some more pics tomorrow.
Bl4cK32, i am thinking! im thinking of who i can call to help me out! lol.
i want the axle to go down, not go up. if it goes up it makes the gap even greater and it will be harder to put on. any other ideas? i really hope this thread is closed soon.
heres a pic of the current situation.
There is more than enough room to jack the shock up if the car is up on axle stands. And by trolley jack, yes I do mean the ones with wheels :) You just need to push the shock up in a kind of next-to position to the stud, and then kind of slide it over. It's pretty easy once you get it into the right position, which can take a bit of fiddling.
You don't need a spring compressor but it might help if you can't do the jack trick. Keep in mind that new shocks are pretty hard to push up on their own anyway so you might need the jack regardless.
Turn the spring compressors upside down and squish the springs while you put the struts in. Then undo them when the strut is in place.
If you can't fit the jack in, it should be easy enough to use brute force to pull the suspension arm down a bit while pushing upwards against the shock and slide it onto the stud.
The more I think about it, the more I think I just used the jack for the rear and just used brute force for the front (no spring compressor for me).
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
