I have a forward facing plenum for an RB20det I got with the car that I don't need.
What you see in the pictures in what you get. It looks fairly complete.
I will start at $220.00 ono
I am located in Brisbane with Pickup preferred, or the purchaser to arrange their own freight.
Please email kirstennick@optusnet.com.au or call 0412 547 402 if you are interested.
Thanks
not to be a nay sayer but isn t there a reason why you don t put a forward facing planum on a rb20?
I remeber my performance mechanic saying people had tried it and it did something wrong with the motor.
I could be wrong but that is what he said when a mate of mine asked to modify his rb20 planum to forward facing.
Leafy Bug
You would have to at least modify intercooler piping, and your throttle cable.
As for the computer I don't know sorry.
Maybe.... just maybe GTIR-Keiron's (comment above) 'performance mechanic' who is an RB20 guru might be able to give you some performance advice though. It really sounds like his his mate's, wife's, cousin's, roomate's, aunt knows what they are talking about.
R32_Abuser
Thanks mate I have replied to your email with some options. Perhaps if we were to go ahead with a deal we should get GTIR-Keiron's 'performance mechanic' to provide some independant consultancy services, and a complete a full compare and contast report on the efficacy of the RB20 forward facing plenum, versus the standard plenum. Sounds like he really knows his stuff.
GTIR-Keiron
Thanks for the input buddy/nay sayer. Ive sent you a PM requesting you to edit your comments. Please keep your unquantified comments out of other people's threads. Why waste everyone's time here?
in light of GTIR Keeirons amazing advice i guess i should remove my forward facing plenum which seems to be working quite well and funnily enough dropped my intake temps but hey if MR K says so ill have to take it off
on a serious note these things are great and shorten your intake pipe by almost 1m if you use a standard cooler with an outlet on either side and less intake pipe means less air volume to take the car from vacum to boost
but hey just my 2c good luck with the sale mine cost more than this
Thanks 'ez 10'.
It's good to get some quantifiable performance gain info.
They are supposed to be a really good value mod.
I would fit it, I just want under my bonnet to look standard.
Edited by NW007
would love this if it was straight bolt on ....so how do you modify the throttle cable? just extend it? how did you do your one? any pictures of it installed?
Your standard throttle cable may already fit seeing as it has a standard throttle body?
It should just bolt straight on top of your intake manifold with some minor intercooloer plumbing changes?
I don't have any pics of it on the car as I have never had it on. I got it with the car when I bought it. Here's a pic though of one I found. It looks like a standard one that's been modified slightly differently though?
http://media.photobucket.com/image/rb20%20...n/april2005.jpg
i did the same thing to my 25 plenum but with a 90mm throttle body it gave me another 13rwkw but this was tuned on a hot day (got retune because it was running little rich cause of the volume of air in the intercooler changed) i used my std cable too. it made it more responsive also, to get this done it will cost at least 300 or so depending on the place u go to
Thanks 8znR33. Good info!!
Yeah they say they go well.
$300 you say for the mod?........ and I bet that is supplying your own too?
At $220.00 this is a bargain people!
hey sorry been a while since i was last on but yea the mod cost me 300 and i supplied the throttle body as well.
I'm not here to say anything ill of the item since I've seen it a couple times before. But I know with the stock form of where the intake is in the middle of that manifold when it comes in sideways in as stock, cylinders 5 and 6 are naturally lean. Now, moving this to the front, which I can tell is a well done job from the welds and such, will the intake be as lean or more lean than stock in cylinders 5 and 6 since the air is directly into the first several cylinders.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
