  • Replies 101
like said in previous posts. im knew to the whole skyline bit,
looking to get more power from the car.
its relatively stock.
with front and rear sway bars.
adjustable coilover all way round.
walbro fuel pump
eboost controller
turbo timer.
what do people suggest as a start.
oh and its running 10psi
how much you aiming for?
standard exhaust im guessing? if it is, call Andrew at AM Performance on 0401865373 and get him to hook you up with a turbo back system.
get yourself a front mount kit, id just buy a cheapo chinese core and again see Andrew to do the plumbing.
crank it up to 14psi, have everything checked out a dyno, and enjoy it for a bit.
then when you get bored (you will), start looking at turbos (steel wheel highflow will see you into the 200's), injectors, and ecu's.
then when youve got all that taken care of, start looking at keeping your engine reliable. oil cooler, maybe an ungraded radiator.
but before all that, basic brake upgrades. some rotors (rda slotted rotors are available cheap cheap like a budgie in the group buy section), uprated pads (i and many others will recommend qfm pads) and a set of braided lines.
Edited by scandyflick
forget about these waste of time/money mods dave has mentioned.
get yaself 1 of these puppys
http://www.nengun.com/nismo/radiator-cap
you'll be ripping 10sec 1/4miles the second it go's on
Fark! I was going to get one of these instead.... good thing I read this one first hey ;)
sorry i forgot to mention it has a FMIC and as far as im aware it has a turbo back exhaust.
cheers for the ideas and suggestions. but in relation to cranking it up to 14psi. i was told to go no higher than ten because the stock turbo can not handle much more or something like that.
What he said ^ Just make sure you get the AFR's checked out on a dyno.
Edit: Hypergear say thier highflowed stocker can pull 225RWKW @ 16PSI on a RB20, so it would be higher for a RB25.
You will need to upgrade injectors, AFM, fuel pump plus look at your ECU to get those power levels safely, though.
a quick check inside the passenger left footwell will tell you what ecu you have. 14psi, hiflow turbo, 55cc injectors and fuel pump should see you safely into the 200's
cheers for ya help. already got the fuel pump, where would you reccomend for getting my turbo highflowed. and the 55cc injectors
Wow! I never knew RB25s could use such small injectors. No wonder they are such pussy engines. ;)
*Make sure your sarcasm alert is set to the 'on' position*
lol @ 55cc injectors. my lawn mower uses bigger squirters! ;)
send your turbo to hypergear for a highflow (theyre in the traders section here and on ns), itll run you about 800 samolians. 550cc injectors you can get basically anywhere, send a pm to dohmar on here, hes got a pretty decent thing going on with some americans (yeah, i know...) for cheap injectors.
You will need 550cc injectors, he left off a 0 lol
I have never used them, but Ive heard good things about Hypergear (www.digi-hardware.com)
What fuel pump do you have?
Also, you will probably need a Z32 air flow meter.
Then there is a couple of different options for ECU and tuning. You could go a Apexi PowerFC and have it tuned, the FC is ~$1500, then you need tuning. Or, call Jeff at The Speed Lab (0434637357) and have a talk to him. This will be cheaper.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
