  • Replies 101
unsure on the specifics of the fuel pump, but i know its a walbro fuel pump. i'll try find out more info when i ring previous owner later on today.
where is "The speed lab" located as im in norther adelaide. but will travel if its worth it.
bloody hell all this turbo jap car business is confusing.
ive got a hypergear rebuild in my car, and i cant fault it.
alternatively, japanese import spares have a 2530 to suit an rb for under $1000.
they also have nismo 550's for $240 each if you cant be f**ked waiting. but its easy to find injectors for much cheaper.
jeff (speed lab) tends to work out of turbotune on the other side of town. and actually, this turbo jap car stuff is pretty straight forward. dont have to pull half your engine (and half your car) apart to change a cam. ;)
Edited by scandyflick
if its a "500HP" pump, it will be fine.
Last I heard Jeff was working out of a place at Pooraka.
haha cheers ill be giving him a ring asap
and yeah i guess your right, i've always had big v8 engines, just gonna take some getting used to.
Takes just under 2 weeks from the time I recieve money, but I can supply 555cc injectors for an rb20 for under $400 (set of 6)
Am expecting injectors for Dark.Sky and MattyR31 this week and injectors for DSTROY next week.
-D
on the topic of injectors, i noted a certain united in the pt adelaide area advertising E85? if its gonna hit hard this time i may consider changing over.
+1 If it becomes more widely availible I might look into it.
fair enough.
bah, stupid rb's and their crappy ceramic turbines. get a highflow, then smash 16 psi. easy. :(
My old 32 ran 16psi day in day out on an R33 turbo and didn't miss a beat, and you saw how harshly that was treated Dave :wave:
Edited by AndrewJZX100
lol. that thing was flogged hard. but it was also 2 steps away from being a missile car. fairly sure this guy wants his to stay in one piece! :wave:
That may be so, but my main point was the R33 turbos can handle a bit of abuse :P
If it was my car I'd go front mount, decent exhaust (turbo back 3inch with no cat), fuel pump and run boost around 14psi. Turbo should handle it, injectors might be pushed but everything should hold together and make near enough to 200 @ the wheels and would still be responsive. Would be good fun for a bit till you get used to it and want more :(
R33 turbos on a RB20 arent put under the same heat and load hence why you can boost it to 16psi
i ran my RB25det to 14psi for about a year before she went bang and didn't properly go bang just made a little noise i recon better oil may have not done that too AFR's wont stop your ceramic wheel going pop
possibly best route
Garret 3076
Injectors 555 if you not going to entertain the idea of E85 or else 700+
PowerFc if your real keen or else speak to Shaun @ boostworx for a VG30dett ECU conversion
get rid of the walbo and get a bosch
and
Z32 AFM
tune to 18psi and let the fun begin can go higher if detonation is low tunner will know how much you can go
possibly best route
Garret 3076
and
Z32 AFM
+1 this dude knows his stuff
-D
possibly best route
Garret 3076 - Got
Injectors 555 if you not going to entertain the idea of E85 or else 700+ - Got Nismo 740cc
PowerFc if your real keen or else speak to Shaun @ boostworx for a VG30dett ECU conversion - Using a Haltech
get rid of the walbo and get a bosch - Using a Bosch 040
and
Z32 AFM - Dont have as I am using MAP sensor
That is a very good combo, i am running 15psi and making 265rwkw. If you are wanting to retain more of your response i would suggest a hiflow or the 0.6 a/r for the GT3076 turbo. I am running a 0.82 a/r, a little bit laggy, but boost hits nice and hard :P.
Maybe also replace coilpacks with either Yellowjacket/Splitfire/Superspark, depends on what condition your stock ones are in.
