Sau-vic Show'n'shine
R31Nismoid
 Share
  • Replies 138
Dan...it's a carnauba paste made from only the best Brazillian soccer players. Apparently just breathing in the vapours will suffocate you with a thick layer of carnauba oxide. Using it to port and polish your head will make the ports so slippery, air actually accelerates as it travels into the combustion chamber, creating some form of pseudo forced induction.
Well that might be stretching the truth but it's a very cheap and very awesome wax...couple of the boys who were at the photo shoot the other night will vouch for that :P
If only I had the time to put on two layers :D
Wicked! I'll be there... fresh paint does wonders!
Is there any categories for best CHICKS skyline.. lol
So much for equal opportunitys and all that.
It will have a hair tie on the gear stick if its a chicks...
unless your mrs drives your car too :P
I will try and make it down to have a look, but the stagea is getting looked at, i am helping a mate move and the 32 isnt show worthy, so I will not be entering either car. Stagea is nice and clean but hardly show worthly.
Want to see your GTR anyway Chris...
btw PEARL JAM WAS AWESOME.
that is all :D
BTW, Ash, will someone have spare SAU stickers for members to purchase on the morning to have all the cars in the SnS wearing one, making the club a bit more visible?(kinda hard to miss an SAU sticker on every car you look at :blink: )
Ahhh you idiot Birds, sure your car is clean but you'll be sleeping in it for most of tomorrow lol. Thought I'd give it one last wash on the way home from what was supposed to be an early party...gotta give me credit for the dedication!
I was gonna be there but im guessing that after discovering a small injector leak and estimating a loss of around 10 litres between Berwick and Pakky, i dont thihnk its a good idea to drive the GTR....
Well I won't go into detail with what I had this morning but there's no way I could have stayed at a static car display all day! Weather turned out awesome for yas...overcast with no rain is the best for viewing waxed up beasts. Lol TJ no wasted effort there ;)
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
