  • Replies 138
Dan...it's a carnauba paste made from only the best Brazillian soccer players. Apparently just breathing in the vapours will suffocate you with a thick layer of carnauba oxide. Using it to port and polish your head will make the ports so slippery, air actually accelerates as it travels into the combustion chamber, creating some form of pseudo forced induction.
Well that might be stretching the truth but it's a very cheap and very awesome wax...couple of the boys who were at the photo shoot the other night will vouch for that :P
If only I had the time to put on two layers :D
Wicked! I'll be there... fresh paint does wonders!
Is there any categories for best CHICKS skyline.. lol
So much for equal opportunitys and all that.
It will have a hair tie on the gear stick if its a chicks...
unless your mrs drives your car too :P
I will try and make it down to have a look, but the stagea is getting looked at, i am helping a mate move and the 32 isnt show worthy, so I will not be entering either car. Stagea is nice and clean but hardly show worthly.
Want to see your GTR anyway Chris...
btw PEARL JAM WAS AWESOME.
that is all :D
BTW, Ash, will someone have spare SAU stickers for members to purchase on the morning to have all the cars in the SnS wearing one, making the club a bit more visible?(kinda hard to miss an SAU sticker on every car you look at :blink: )
Ahhh you idiot Birds, sure your car is clean but you'll be sleeping in it for most of tomorrow lol. Thought I'd give it one last wash on the way home from what was supposed to be an early party...gotta give me credit for the dedication!
I was gonna be there but im guessing that after discovering a small injector leak and estimating a loss of around 10 litres between Berwick and Pakky, i dont thihnk its a good idea to drive the GTR....
Well I won't go into detail with what I had this morning but there's no way I could have stayed at a static car display all day! Weather turned out awesome for yas...overcast with no rain is the best for viewing waxed up beasts. Lol TJ no wasted effort there ;)
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
