I've got a gauge pod for my 33 and so far i have a boost gauge installed. Im not using any other after market gauges.
Im trying to decide what gauge to put in the second hole of the gauge pod. I considered Air/Fuel Ratio but it doesn't tell you much other than look pretty. I've heard bad things about the stock water-temp gauge in the dash of 33's, though mine seems accurate.
What would be more useful to have? Oil Pressure or Water Temp?, or something else? Oil temp is a bit of a pain to fit..
Brad
https://www.sau.com.au/forums/topic/295451-water-temp-or-oil-press/
Brad
Anyone? Im still having trouble deciding :(
I've got water temp there, which is great to check if the water is getting too hot (which has only happened once), but oil pressure is more important (which would indicate an engine / oil issue if it was too low)....
