Alfred Y Posted November 9, 2009 Share Posted November 9, 2009 Hi all Need some advices for checking the second hand suspension. I have buy a set of HKS suspension for a ER34 GTT (2 door)but I don't know how to do some basic check for the coilover. Can you guys give me some idea or advice? Thank you for everyone help!! Link to comment https://www.sau.com.au/forums/topic/295455-how-to-check-the-used-suspension/ Share on other sites More sharing options...
Equinox Posted November 9, 2009 Share Posted November 9, 2009 Take the hats and springs off and put the shocks on a shock dyno. Link to comment https://www.sau.com.au/forums/topic/295455-how-to-check-the-used-suspension/#findComment-4927441 Share on other sites More sharing options...
benhpi Posted November 11, 2009 Share Posted November 11, 2009 Check the dampers (shocks) for any signs of leaking or visible wear on the shaft. Turn the shock upside down and use your weight to compress it. Each damper should take about the same amount of consistent effort to compress. They should then return by themselves to full extension fairly quickly. If some take a lot longer (or don't come back) they could be worn out. Make sure any damper adjustments are set to zero when you do this check. A shock dyno is of course much better but not free. Link to comment https://www.sau.com.au/forums/topic/295455-how-to-check-the-used-suspension/#findComment-4930507 Share on other sites More sharing options...
