Firstly, I don't think there are any guides as this is so simple to do.
However, you can try Googling it. However, here's a quick guide for you...
1. use your thumb and second finger to make a "C" shape. Put your fingers into the side area of the the light enclosure and you should see a little pointer thing stick out. This is the side parker lights cup enclosure. Use your thumb to put on the lever hold it in and with your second finger - just push down gently and it should pop out with minimal resistance.
2. Go to Autobarn or Repco and buy yourself a set replacement parkers, I suggest you get the Phillips ones and not those cheap ones that burn out without 2-3 months. Remove the old (not working) parker globes from the cup enclosures and replace with new ones as appropriate.
3. Now using your fingers, put the parkers back in gently and remember to use your thumb to push the lever into the casing. You should hear a click sound if it's in nicely. Check to see if the parkers are working of course before you put them back in to save time removing them again. That's it!
It's quite simple. You just have to be patient and also remove the squirter water bottle if required to make more room.
Good luck.
PS: Don't put blue or red ones in as you can be defected for something that's going to cost you less than $15 bucks. Sure they look nice but are illegal!
I'll add some photos of the Passangers side park lights. Is this the correct location?
Passenger side park lights
Passenger side head lights
That's it! Just do what I said and you should get it out no worries. Remember to be gentle.
And in some cases even the 'white' LEDs you can get done for (that was something I was picked up during a Regency defect inspection that I had to change my white LED parkers (purchased from Dan666 on these forums) back to regular bulbs because they showed 'too much blue'....
Jenna, do you want me to send you the light wavelength analysis we had done on the globes? :P I had to supply it for a similar "offence" in QLD as part of a defence.
Basically the wavelengths emitted by our lights are 100% WHITE on average, and the same as natural daylight...BUT when next to an obviously yellow light it appears 'blue' as white LEDs are less yellow.
So basically they don't emit blue light at all, but they are LESS yellow than a normal light. It's a massive difference when it comes down to the letter of the law. So much so that they actually fall within the allowable deviation of colour allowed on a standard bulb.
The same thing can be said for putting a white LED next to a blue one, you'd never say the white LED was blue in comparison
Always good to know the specifics :D
A nice bit of info from QLD transport-
"Blue" halogen bulbs are a recent innovation in vehicle lighting technology. They operate at
higher temperatures and provide superior illumination to the conventional halogen bulb.
Historically, the white light emitted from headlamps on motor vehicles has been generated
from incandescent light sources and contains a predominance of red/yellow frequencies.
This has become the accepted norm for white light. The new bulbs, which are actually
"whiter" than the existing bulbs, contain less of the red/yellow frequencies and more of the
blue end of the spectrum. The bulbs may be perceived as a very light blue.
Motor vehicles have been required to comply with Australian Design Rules (ADR's) for
lighting since October 1991. ADR 13 mandates the number and position of lamp assemblies,
ADR 46 prescribes the photometric requirements of the lamp itself and ADR 51 is the
standard for filament bulbs.
ADR 51 accepts ECE regulation 37 as an alternative standard for filament bulbs and
prescribes the dimensional and photometric requirements for filament bulbs (including
headlamps). This ensures inter-changeability and correct functioning when installed in a
complying lamp unit.
