Last week I had a megasonic BOV fitted and I also put on an apexi power intake pod filter myself on the same day.
BOV sounds nice (despite only running stock psi), and of course the pod has makes a nice induction noise. Car runs smoothly and fine as it did before these 2 mods were made. However, after I change gears, a loud and distinct pop/bang sound is made about 1 or 2 seconds after the BOV goes off. The popping sound sounds like it's coming from somewhere in the exhaust system (judging from what I'm hearing, I assume it's somewhere just after the cat). It doesn't happen all the time but it does happen at least 2 or 3 times when I'm driving.
Just need to know if this is to be anything to be concerned about. If it's causing any harm or damage internally and is it something I should get attended to straight away?
Thanks in advance and apologies if this has been posted already!
https://www.sau.com.au/forums/topic/295500-concerning-sound/
A mate of mine had this same problem with his 200sx. Maybe try adjusting trhe bov tighter. It may be dumping too much air and then running rich for a second, and the rich mixture ignites in the exhaust. causing the pop. Someone else may be able to explane this a little bit better but i think that would be your problem.
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
