Stagea Gps/dvd Conversion To English/australian Maps, Melbourne Based
Is there anyone (in Melbourne) who is able to change over GPS to English and australian maps without removing the dvd player/ reversing camera in a 2003 nissan stagea 250t RSfour? It's a panasonic Display unit model no TR-T70W2 and the dvd rom is a panasonic CN DV2200.
Cheers
PM me with price
rip the unit out. you can re wire the reverse camera.
how easy is that to do TJ?
I've had a brief look, so take the dvd system out and leave the screen in yeah?
when i got my head unit installed, they cut the amp wire's and re wired it from the cut to match the Australian plugs to go into the head unit, so im still running factory amp and speakers and sounds good enough!
so i guess the same could be dont for otherthings.
If Chris Rogers can do it, maybe he can reccomend someone down here who might be able to?
that sounds like a very good idea...
I want to get it done, and i also want to get GPS and everything hooked up...
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
