Hey guys,
No doubt some of you may have read about my RB25 overfuelling (I know, I know, those of you who have are probly ALMOST as sick of it as me...
Anyway I keep testing things & results keep changing! At first car idled like crap, after a LONG time, found disconnecting AFM made it stop smoking & hunting (although it still smelt rich & obviously is in limp mode) Had around 1v at orange/blue AFM wire at this stage...
Then all of a sudden one day it started fine! Thought problems were solved until I gave it a rev & found it was in limp mode. Found AFM wires had to be wiggled & held a certain way for AFM to connect properly & when it did it started hunting again, voltage at orange/blue pin on idle was 2.4v!
NOW, car wont start at all, so checked voltage with ignition on only...
Black/white trace has 12.4v
White/blue trace has 11.1v
Orange/blue trace has 9.9v
Surely these wires shouldnt have voltage (or not so high) with only ignition on? If anyone knows for sure, would be great...
This car is starting to drive me bloody nuts!
Ok, had an ECU in the car borrowed from someone (to eliminate my ECU as being problem) & obviously it wasnt too happy as car wouldnt start or run with it in place... Put my ECU back in & no longer has voltage at all pins but still has around 2v at orange/blue wire on idle... Should be around 1.4v as far as I know? Any ideas what could be causing high voltage? Obviously the ECU sort of thinks its pulling in more air than it should on idle so its adding extra fuel... (last time I had a scantool on, injector pulse was 7ms at idle)
Will check resistance of each wire back to ECU & report back in a few minutes... Damn its hot too!
might be an idea to unplug both ends of the loom and check resistance between the wires, there might be a short somewhere.
its my understanding that on a cold start under 3k rpm the afm won't have much effect on anything the temp sensor does however.
but this is all irrelevant if the car is not even starting now.
who did the wiring?
Have just done that, as written above. Car is also running now but still reading 2v at signal wire on idle which is still a touch high... Temp sensor has been swapped for a known working unit & temp sensor wires have also been resistance checked back to ECU plug.
Wiring was done by a member on here. Nothing he has done could cause this however... Have no doubts in his work...
still not quite sure you understand what i said, just to make sure im saying put probe on one end of white/blue and the other probe on the orange/blue, you should get infinity if not you have a short, i would also check them between ground too.
the guy who did the wiring may have done a good job but maybe when the loom was installed it got damaged on a sharp edge etc..
OK got ya mate. Sorry, when you said unplug both ends of loom, was assuming you meant to test resistance between AFM plug & ECU pin...
Will give that a shot. Anything is possible... Open to any thoughts at the moment as Im just running out of ideas & things to check...
One of them should be ground, one should be 12V supply (should be able to measure this with the AFM disconnected) and the other should be a 0-5V signal from the AFM.
Definitely sounds like either a grounding issue or the loom has been pinched and the wires are shorting.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
