I have had a search but not uncovered any hard information;
What is the largest frame turbocharger that will fit on the standard RB25 manifold and not hit the strut tower/ frame rail?
I know people have fitted a GT3076 with a 10mm spacer and there is clearance, but how about GT35 etc.
I appreciate that most people wont run the std manifold on large-frame turbos as the stock unit becomes restrictive, but any info would be great
Cheers
* EDIT: I probably should clarify so I dont sound like an idiot-
I have a Holset HX35 (trying to keep it under wraps until I have it all together) and Im trying to work out (without test fitting- lazy) how much room, if any, I am going to have.
From what I can gather, the HX35 comp housing is bigger than a GT30 size, and Im a little worried about it.
All of the other Holset applications I have seen have been in R32's/ RB30s or on high mount manifolds.
Cheers
Edited by Yeedogga
GT35 is the same size as a GT30 in terms of frame.
I think a few people have tested the stock manifold useless after about 300rwkw though, which isn't even near GT35 territory anyway so no real point in many ways.
There are a couple of options but as Nismoid said pointless if the manifold can't pass enough exhaust gas to make it worth the while .
Two that spring to mind are the T04Z with a T3 flanged T4 turbine housing or a T3 flanged version of the GT37xxR turbos Garrett sell to the "deesel ute mate /aircraft carriers in the US market - think GMC/ Dodge Cummins Ram/Ford F111 .
Both the T04Z and the GT37 BB turbos are the larger BB "frame" or shaft/center section units . Probably need at least a HKS cast low mount manifold to even start to flow well enough .
A .
  • 9 months later...
Resurrecting this thread- I bolted the turbo to a manifold on the weekend to see how much spacing out it would require...
It just looks far too big to fit down in the stock location... Does anyone know the diameter of a GT30 comp housing??
What you think, will it blend? (sorry, fit...)
Any thing fits a .70 comp and 1.0 turbine with a 12mm spacer will do the job. But fitting up an internal wastegate and setup its bracket to operate without hitting any thing is very difficult.
  • 2 months later...
any luck with this? i am looking to do the same, which means plans have been on hold till i find out if it fits. have you tried positioning it in the engine bay yet? what kind of clearances are you getting (if any?). any guidance would be much appreciated. cheers, Daniel
So a .7 ar GT60 comp housings will fit?
I dont think so
I dont think so
LOL @ above. Le sigh, strippey horse I know your pain.
GT3582R .70AR = Centre of turbo to centre of outlet = 76.2mm
GTX4202R .60AR = Centre of turbo to centre of outlet = 108mm
AR = Aspect Ratio, not fking cm2
but .7 is bigger than .6 :blink:
as already said its pointless running anything bigger than a gt3076 on a standard manifold as it becomes a massive restriction above ~280rwkw
  • 2 years later...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
