Car Issues....losing power (Still) Help!
Howdy All,
Unsure if you remember but a while back I was having power loss probs with my car, here is the scenario:
- Car will run perfect but suddenly lose power and not go anything over 2000rpm.
- If it does this and I stop the car, turn it off, and turn the car back on again 8/10 times the car will run perfect again.
- Car will go up to 200 - 300km's of travelling sometimes without this problem happening..sometimes more.
- Also does not seem to have anything to do with outside air temp ... it happen on a coldish night and also a hot day.
- Fuel levels don't seem to be an issue, only thing i have noticed it seemed to do near 1/2 full and close to empty ?
Since then I have taken it to 2 places and they can not find a fault with it and it runs perfectly when the check it out and run it on the dyno.
I am basically out of idea's except trying a new ECU & AFM.
Does anyone out there have any other idea's? , any Mechanic's out there that have seen anything like this b4?
BTW the engine is a 1G-GTE Twin Turbo.
Help!! :cheers:.
Rob.
https://www.sau.com.au/forums/topic/29552-car-issueslosing-power-still-help/
With R33s at least, the plastic ECU connector can warp under certain conditions and some of the connections come appart. Mine was having intermittent fuel pump probs due to this (a relay connection) and when we reinforced the connector it has been fine for over a year.
like i said b4 in an older post. I had very similar problem to u. Turned out to b the loom plug into the ecu and the ecu itself.
So i changed both and fixed the afm and it worked. im thinkin the reason no one can find the problem is because it is a connection problem where everytime someone is lookin at it, it is fine.
Yeah that's the one Enrico, the loom plug.
Steve, it was very involved and highly technical ;) . We used stuff called Black Insulation Tape (this is very expensive nuclear radiation proof material, only available from the US Defence Dept.!) and stapped it up around the edges. It only became apparent when we did the Microtech plug in.
ROFL only Joolz could get a pic of elec tape that quick....classic :D
Cheers thanks for the info guys, gonna have a good look at the loom and see if i can get another ECU to try out in it.
Let's hope for a good outcome!!
On a lighter note my car makes 100 RWKW on stock boost.... feel the power lol!
But hey it also gets about 410km's on 47 Ltrs of Fuel ... I can live with that ;)
Rob, I think I had the same problem as you before, but mine was because of the AFM, I took my car to few different places and no one can find the problem. All they said the problem could be from:
1) the AFM
2) may be there has some bad connection somewhere in the car
3) the connection of the ECU
They tried the connection of the ECU and problem still there, so I went to the other shop and they clean the AFM for me, and things seem to get better. So, I went home and I changed my old AFM back and the problem was gone.
*I found sometimes the AFM has problem, but we just don't know, because they still look clean and good.
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
