just put an rb25neo into my r32.
i dont knwo why its not starting.
its definitely getting spark.
the injectors are pulsing
and fuel is getting pumped to the rail
how can i check if the cylinders are getting fuel?
thanks
https://www.sau.com.au/forums/topic/295525-is-my-engine-getting-fuel/
compression is good and it would still start with low/bad compression
can i check timing when the only thing turning the engine is the starter??
pretty sure the wiring is ok if im getting spark and injectors. i only want it to start. so i only wired up whats needed for it to start.
CAS is definitely plugged in
Edited by beRwick_GTRage
Have you got the fuel lines onto the rail around the right way?
If the cylinders are getting fuel, then the spark plugs should be wet with unburnt fuel. You could try pulling an injector and watching the spray pattern while cranking the engine (put the injector in a jar or similar).
Buy yourself a ''noid'' light. plug noid light into 1 of the injector plugs. If she lights up, you have inj pulse.
If everything else is working, look at having your injectors cleaned.
Edited by r33cruiser
