Hey i like this model Nissan Skyline HR33 GTS-T Except i need the non turbo ed model what model would that be i been trying to find it but i have a asleep brain atm would they come with a RB20DE ?
-Nissan Skyline HR33 GTS-T White 5 Speed Manual Coupe (Need non turbo ed model)
-Plus Would it be possible to later put a RB26DETT Engine into it without too much work ?
I know they use it in all these
Nissan Skyline GT-R R32
Nissan Skyline GT-R R33
Nissan Skyline GT-R R34
But i don't get whats with the HR33 ?
"G" Gran
"T" Turismo
"S" Engine has a Carby
"T" Engine has a Factory turbo
Sorry as you can tell I'm new to Skylines
Thanks
https://www.sau.com.au/forums/topic/295528-nissan-skyline-hr33-gts-t/
the model code has nothing to do with the engine. RB motors in r33 skylines never had carbys.
HR33 = GTS - have a single cam, non turbo RB20, and it would be gutless, plus there was never a turbo version of an HR33
ER33 = GTS25 - RB25DE (most people just call it a GTS as opposed to a GTS-t)
ENR33 = GTS-4 - RB25DE w/ 4WD. model code is GTS-4 - a non-turbo all-wheel-drive
ECR33 = GTS25t - RB25DET this is the popular turbo R33 that everyone has
BCNR33 = GTR - RB26DETT, AWD etc etc...
and yeh, G= Gran T= Turismo (gran turismo is a french phrase meaning grand tourer)
S= sport, T= turbo, 4= AWD and R (as in GTR)= Race.
in short bro
this model doesnt exist...
[edit] and yeh, you can put a 26 in it later down the track, but i doubt you realise how much of a job it is, plus the 4-5k you'd be up for.
Edited by turbo x-trail
in short bro
What if i knew a mechanic n they put it in for free how much would engineering cost ?
OR
What would be the easiest non turbo ed motor to put in the HR33 ?
Thanks
Whats the fixation on the HR chassis mate?
They're nothing special, virtually identical to an ER33, minus the motor, in which the ER33 RB25 is MUCH better. forget the HR33... Even if you try to drop some other non turbo motor in, the car still,
is not eligible for import.
And I doubt a mechanic would drop a 26 into an R33 for nothing bro, the motor alone costs about 4k so you're up for that plus another 1k for little things like hiring an engine crane, engineering costs, mod plates, emissions testing, vehicle inspections etc... I don't think you realise how much of a job it is to just "drop" a motor in. Plus then you'll need to upgrade breaks, suspension and probably running gear to cope with the added power.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
