  • Replies 224
Who here has a laptop with wi-fi? :P
All we need now is a generator and a evap cooler on wheels (or fans) :P
There was a bloke in the FS thread selling an evap cooler for $50. might see if we can grab that
i got laptop with wifi but more importantly Next G :)
-D
Edit - its nick who has the aircon, just messaged him about it. aircon consumes 210watts, which is bugger all, so I reckon that might even run off an AC inverter from a deep cycle battery
i got laptop with wifi but more importantly Next G :P
-D
Hehe I got this:
10GB Download Limit.
Thats why I asked who had wifi on thier laptops :P
-D
awesome get the ac for the shows in the summer
Hehe I got this:
and i will def bring my laptop then lol
If I was more organised I would have brought it to Loxton along with my laptop. But Im sure you saw all the clothes on my back seat still drying so thats how organised I was lol
Thats the idea... we'd need power tho, thats the only problem (unless someone has a deep cycle battery with 12 hours of 400 watts load.
Aircon draws something like 250 watts (say 350 for initial load when powering on) and the router takes 18 watts, so 400watt inverter would be good. Otherwise it'd be an AC plug from somewhere or a small generator
-D
my truck has 3 batteries and my father in law has a new 2.0hp Honda generator.......would have to break his arm to borrow it though.
ok, ill get SA investigations onto it, might use my 10% discount!
the 2hp genny would be infinately more preferable to the battery and inverter route, however it also comes down to how much juice it drinks and how loud it is (and how stinky the exhaust is)
-D
Put me down for this one. Damo you have a PM mate
Cool, looks like we'll have a nice range :sick:
Next question - Mal has said that if we get there early we can get a good spot - how many of ya'll can make it at 7:30 ?
-D
Cool, looks like we'll have a nice range :P
-D
Yeap count me in on the early start
I'll be in for the early start Ben. Sent Damo a PM regarding details of car entered, but im sure most of you have some rough idea :banana:
spill the beans already :)
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
