i'll sort my entry form out over the weekend. i can bring the trailer if you want me to :P its a lil rusty in spots and prob needs a clean after craigs 31 leaked stuff over it LOL.
pity i dont hav an awning yet LOL, that would be killer for shade
anyone from south need a tow down (martin, bring both cars maybe, can chuck one on the deck for ya)
sticker wise, hopefully get my sticker(s) by then for the windows........
  • Replies 224
I really need the following entrants to confirm their attendance
Damo: R34 (confirmed)
Dion: R32
Ben: R32
Krishy: R33 (confirmed)
Andrew: V35
Shane: R32 (confirmed)
Mitch: R33
James: R33
Anthony: R32
Matty: Patrol (confirmed)
Hutchy: R33
Holty: R34
Martin: R32 (confirmed)
Troy: R34 (confirmed)
I paid as well, easy enough to grab a money order from the post office, send it off with your entry form, and not have to worry about paying at the gate on the day.
I wonder if Andrew can work on Munro to bring the 35 for the day? :P
He works on Sunday unfortunately.
I could bring out his R35GTR for him .... but that would mean leaving my V35 at home :D
Matty has a free trailer, depends whether you wanna drive the V or the R :P easy choice.
I will pay for the entry of an R35 owner (not that they need it :D ) if they are willing to attend with their car. This will include me sitting next to the thing all day making sure noone comes within 3 metres of it!
and if i had to take one on the trailer, it'd be loaded and securely stored at my place the afternoon before (as i gotta go out sat nite and sun morning is going to be a push as it is :()
*cough*
andrew - i'll take the V35 for ya
*cough*
    • This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
    • good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
    • Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me.   Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt.   Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension.
    • Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
