Power To Weight Rules And Engine Conversions?
So, i nearly have enough money saved up to purchase my first car however, finding a decent car is harder then i planned considering i don't have that much to spend.
anyways, while i love rb25s, i don't wish to purchase a R33 because of it's size and weight. on the other hand, i'd rather an engine with some low down torque thus ruling out the rb20 in the R32s.
so, would i legally be able to drive a r32 with a rb25 conversion?
please note, i only have to follow the 125kw/tonne rule, got my license before the turbo bans (luckily).
if not, i'd probably go back to looking at s14s.
My bet would be no.
The R32's just scrape in under that power to weight rule.
An RB25 would in theory put you over...
Also if you can't afford the conversion - have a search they are more expensive than you think.
I would stick to a stock example.
once engineered it goes off of the new motors flywheel figure and a weighbridge figure IIRC.
My turbo is laggier than stock, so a stock RB20 would be nicer to drive than mine :D
i was in the same boat until i chucked in my cam gears
a hell of a lot less of lag and much better to drive
way more steetable
you should invest in a pair ;)
there is not much difference from a stock rb20 and rb25....
stick with the rb20. like i did. i always wanted a rb25 in my r32 but never happened the rb20 is soo good unless you want over 250kw in your case you don't so r32 rb20 ftw. trust me you'll love it....
way more steetable
I have some... I am just used to motors that arent poo :D
just stick with the r32 and do the the basic mods ppl are doing these days if you want abit of power injectors ecu turbo etc and it will be good enough for street on Ps
Nope....... Can't do any of that, apart from sticking to a R32 lol.
P platers cannot mod their cars to put out more power. They can rice it but can't do anything performance wise.
Peter is old rules as I was.
I drove a lightly modded stagea for 2years of my P's without issue. also had a modded 1600, few r31's etc.
An R32 with RB20 or an S14 is best option for peter IMO, as if you need to make an insurance claim, best to keep it simple!
Even with old rules, you still can't mod your engine to put out more power?
on old rules there is nothing wrong with upgraded exhaust and intercooler. Thats about all you can really do.
Larget turbos, boost controllers, ecu tunes, larger injectors etc are all illegal regardless of P-Plates or not.
old rules, everything goes that's legal(not that much really is considering EPA) as long as the car doesn't go over 125kw/tonne.
rb20s lack the torque, 25s have far more stock (267nm vs 330nm to memory). i planning to keep the car for a good few years when i buy it, so rather not muck around with a conversion after 6months. thought it would be easier just starting with a 25 in a r32.
probably keep looking for s14s.
R32 then engine conversion when off p's... its not just the peak torque of the 25, but the power delivery in general...
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
