to begin i have a r3 s2 (auto, 103000k on the spedo)
the problem is when it have the car in gear and come to a corner with the brakes on the cars starts to run rough (close to stalling). I have taken it to a couple of the local mechanics to get it solved but with no luck. (live in a small country town not much here)
The car has been serviced every 5000k,
list of parts that have been changed so far are
O2 sensor
fuel filter
spark plugs
coil packs
afm
fuel pump (bosch 040)
Auto was serviced at 100000k
timing belt (gates)
tensioners
all fan belts
as you can see it is starting to become a bit of a spend on all these parts
If anyone has any possible ideas it would really help out.
https://www.sau.com.au/forums/topic/295542-need-help/
took the car to the local nissan shop today, They had told me last week that they could look at the car and see what the problem might be. Guess what. They refused to look at the car at all and said i would be on my own in fixing this problem. His reason was that he was worried that they would not be able to find out what it might be and that they were happy to take my money and not fix it. (they have seen the car before, he nows what it is and has ordered parts for it before) Dumb shits.
anyone please,
can you help
https://www.sau.com.au/forums/topic/295542-need-help/#findComment-4931144
check the basics?
when did the problem occur?
whats changed since it started happening?
assume stock bov and intake setup? confirm? yes/no
assume standard boost? confirm yes/no
have you tried ECU reset?
have you checked idle RPM (sticker on bonnet identifies target idle RPM)
have you checked timing with timing light
the common basics will likely resolve this issue
it sounds like its stalling may even be auto box related
has that been checked since the auto box service?
https://www.sau.com.au/forums/topic/295542-need-help/#findComment-4931255
