Hi,
I'm planning on getting some drift teks for my R32 GTS4 in 17 x 9 +35 size all round.
I have been told that a spacer is required to fit the 18" Drift Teks over the R32 front brakes due to the spoke design, does anyone know from experience if this is the same for the 17 x 9's?
Cheers
Tom
https://www.sau.com.au/forums/topic/295546-drift-teks-on-an-r32-gts4/
Hi,
Cheers
Tom
17x9 +35 for the front will probably rub on the suspension. rears will be fine. If you're ordering them get +30 offset. They will be well clear of the brakes. Guards may need a roll.
Have a read...
http://www.skylinesaustralia.com/forums/Wh...0&start=660
pretty sure if you put 215 rubber on it it should be ok
r33 gtr rims fit on the front of an r32 gts-t with no spacers and 215 rubber though they are +30 but i doubt it's <5mm away from the suspension
I run 245/40 rubber on 33 gtr rims front and rear. Very close to suspension. Like as in <5mm.
If he goes +35 with 235 rubber would rub. 215 might get away with.
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
