Just posting this here for a laugh, been a while since i came on these forums. Got this email today --->
R33PER,
susan has sent you this email from http://www.skylinesaustralia.com/forums/index.php.
My name is Miss Susan Godwill, i just went through your profile when i was searching for love,life fulture,Well i have no options than letting you Know that I am infected and affected by your profile at(www.skylinesaustralia.com).that is why i wish to have a relationship with you, I will also like to know you the more,And i will be very greatfull to have you as my loved one.so i will like you to reply back to my private email address Above /[email protected]/,And i will also like to send you my pictures for you to know who i am.I believe we can move from here.But bear in mind that Love has no colors barrier,religious,language,or distance barrier,the only important thing love and understanding here is my email address above. ([email protected]).for more explanation.Thank you for your cooperation From Susan.
what a 'lol' :thumbsup:
https://www.sau.com.au/forums/topic/295549-spam/
yah... she/he/it/heshe looked at mine yesterday.....
just realised it prob not a good idea to have real birthdate up for just anyone to see....
so i changed it, ill be celebrating my 100th birthday in January :banana:
Your probly the oldest man to own a skyline then haha.
https://www.sau.com.au/forums/topic/295549-spam/#findComment-4929079
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
