Hey all,
I know I'm probably going to get flamed for this but I drive an r33 GTST and i'm on green p plates, i got my ps before July 1st.
Got a fine and points for driving it today.
Just wanting to know if anyone has had similar troubles and if there is anything i can do.
I will be defiantly garaging it until I get off the Ps.
Cheers.
https://www.sau.com.au/forums/topic/295563-got-done-for-turbo/
  • Replies 121
^^^^ doubt it?
i have a r32 turbo keep it in the garage most times until 2 months till off me p's yayayay. but i have been driving since off my learners. daily car ftw
33's weigh more so why would a r32 pass as legal? but r33 power is more.
Hey all,
Cheers.
2007? then turbos are legal, however power to weight might not be.
what was the actual fine for? if it is power to weight, you could get it dynoed then show vicroads the power, might work.
^^^^ doubt it?
If you got your P's before July 1st 2007, then you don't have the turbo restriction, only power to weight.
Yes you are right, R33 is heavier, but R33 has a bigger engine 2.5L, oppose to a 2.0L R32.
So the R32 GTST is legal.
If the R32 was stock (which has to be anyway, because on your P's, you can't mod anything to increase power), then it should be fine, also the age of it will also result in a tiny bit of power lost anyway.
You want to know if there's something you can do? What do you expect to be able to do? You broke the law and got punished for it...that's the end of the story as far as the state of Victoria is concerned.
Hopefully you learn from this lesson and garage the Skyline / buy a more suitable P plater car.
I do want to thank you for coming forward and posting this...it should be stickied to serve as a warning to other people that you can get caught for it...and that this is far from the worst that can happen to you when you do drive illegally.
its 3 points and a big fine isnt it?
i got $236 and 3 points, On VicRoads site it says they can fine up to $1100. However I have read on here people have been let off with warnings. Thing is the car is stock, you see P Platers driving much more high powered skylines as well as other cars that are so obviously not legal.
Live and learn on my part i guess...
haha some of the p platers of italian descent around here manage to get around in clubsports and senators without getting dicked, maybe its more of a melbourne thing :P
maybe cause they own half the town with there grapes ?
my cousins family does anyway haha, all the boys of the family are driving around in FPV's HSV's ... Senators, xr6t's bloody crazy up there (robinvale)
i thought it was an impound offense these days. well, consider yourself lucky.
I'll give you simple reply mate...firstly, sorry to hear that you've been fined etc...just gotta garage it and wait until you get off your P's. Driving it is a risk and you'll go paranoid ever time a copper drives past. It's not worth it. Just gotta face reality mate.
Guest
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
