just put on DMS 50mm on my 34gtr. its really nice coilover and i can go corner much better. my setting is
damp:F and R soft to hard 2 turn repound: haven't touch it yet.
only one thing make me unhappy. it make some noise, when the road is flat, the noise like birdcall (zi zi zi zi) not loud i can't notice it if I open the window or music on. but if the road is not flat. it make some knock, all the noise come from rear (I have cut the rear trim for easy adjust rear suspension).
anyone can give some idea??? is that normal??
https://www.sau.com.au/forums/topic/295582-dms-50mm-coilover-make-some-noise/
Were they installed with new strut tops front AND rear? Skyline DMS 50mm need to be installed with new pillow ball strut tops front and rear, you can't re-use the existing tops at either end.
The chirping noise may be a dry shaft seal, prone to making the sort of noise you describe.
DMS used to supply a circular metal "top hat ring" to weld to the OEM pressed metal top spring seat, and a turned out DMS top spring seat to slip over the top hat ring. That way the OEM top seat / and damper shaft bushes can be reused. Pillow ball tops are not required given the design nature of the suspension.
i only have new strut top on front:( they didn't told me i need rear one:(
thank you for help
so the strut top is not required for DMS 50mm coilover?
i went to Neal lowe today (DMS dealer QLD). they reckon the valve make some chirping noise. actually the front and rear all make chirping noise, i just coundn't hear the front noise during drive. if i press the 4 corner of my car, i can hear the chirping noise on all 4 corner. so I assume its normal. but what the knock come from? :banana:
Aftermarket strut tops are required front and rear for the DMS when fitted to the Skyline! We deal with DMS on a regular basis (ourselves and Neil Lowe are the only QLD dealers), and straight from the mouth of the engineer that makes them, they need aftermarket strut tops!
Things must have changed from just a few years ago then, when DMS supplied our ER34 Tarmac struts AND the above hardware to mate up to the OEM pressed metal tops.
The assembly was done locally by the DMS agent with instructions faxed by DMS, and is a good solution that does NOT require new tops.
We still have the struts although they are no longer in the car, unfortunately the instructions were sent on a thermal printout fax so somewhat faded but still clearly indicating they came from DMS.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
