guys, how to check the vaccums of the bov if the vaccum is sufficient to pull the valves of the bov? how much pressure should the vaccum be?, i already check my vaccum lines, and i can feel the vaccum pressure when removing the hose, but i don't know if thats enough to open the valves because the valves won't open, i can only open the valves when i push the valves with something, i can feel i need to exert effect on the valves to open it, and i think is springs are heavy?? i have 2 sequence HKS bov install and i can't hear the "pshhhhhh" when changing gears...
please help, thnx
andy
R33 GTR
APEXI air filters
HKS ssq BOV
APEXI SAFC
APEXI AVCR
please help, thnx
andy
R33 GTR
APEXI air filters
HKS ssq BOV
APEXI SAFC
APEXI AVCR
hav u tried driving the car, or have u just poked the bov with a stick? maybe the springs are too hard, but if they came with the bov they should vent at some point. how much boost are u running? maybe its a sign to put the plumb back stockers back on, and move on to actual modifications.
the bov came with the car from japan, im jealous hearing some stock evo's here venting there bov valves with a loud sound, i tried reving it when the car is in neutral, and also tried it running, it should should open right? i need to open my bov now...il take a picture later...when i push the valves, i think the springn is really hard, im running .8 stock boost... i don't have the stock bov already...as the bov came with the car
Edited by andy95'R33GTR
i have the same set and never had a problem with them on stock boost
are there any spilts in the vac hose going to them?
dont forget to check the feed coming fromt he engine bay from under the plenum
there might be a chance they are rusted shut, give them a good clean dont use wd40 as it will eat the rubber gaskets
the only vid online at the moment is on youtube seach sau nsw drag day mr 32.
these blow off valves are farken loud, you will here them when they open.
this is under the plenum you can see the line marked BOV it goes to a nipple next to the intercooler hose
you can just see the nipple here to the right of the inthercooler pipe opening
the other side joins the nipple and goes to the bovs just make sure you check the air filters for the bovs aswell
mate i dont want to sound rude, but have u even driven the car? you wont get the shit noise your after by simply reving it in neutral. why do you need to open you bov now? if it REALLY worries you, take it to your mechanic :/
