Still Having Problem With My Hks Bov
guys, how to check the vaccums of the bov if the vaccum is sufficient to pull the valves of the bov? how much pressure should the vaccum be?, i already check my vaccum lines, and i can feel the vaccum pressure when removing the hose, but i don't know if thats enough to open the valves because the valves won't open, i can only open the valves when i push the valves with something, i can feel i need to exert effect on the valves to open it, and i think is springs are heavy?? i have 2 sequence HKS bov install and i can't hear the "pshhhhhh" when changing gears...
please help, thnx
andy
R33 GTR
APEXI air filters
HKS ssq BOV
APEXI SAFC
APEXI AVCR
please help, thnx
andy
R33 GTR
APEXI air filters
HKS ssq BOV
APEXI SAFC
APEXI AVCR
hav u tried driving the car, or have u just poked the bov with a stick? maybe the springs are too hard, but if they came with the bov they should vent at some point. how much boost are u running? maybe its a sign to put the plumb back stockers back on, and move on to actual modifications.
the bov came with the car from japan, im jealous hearing some stock evo's here venting there bov valves with a loud sound, i tried reving it when the car is in neutral, and also tried it running, it should should open right? i need to open my bov now...il take a picture later...when i push the valves, i think the springn is really hard, im running .8 stock boost... i don't have the stock bov already...as the bov came with the car
Edited by andy95'R33GTR
i have the same set and never had a problem with them on stock boost
are there any spilts in the vac hose going to them?
dont forget to check the feed coming fromt he engine bay from under the plenum
there might be a chance they are rusted shut, give them a good clean dont use wd40 as it will eat the rubber gaskets
the only vid online at the moment is on youtube seach sau nsw drag day mr 32.
these blow off valves are farken loud, you will here them when they open.
this is under the plenum you can see the line marked BOV it goes to a nipple next to the intercooler hose
you can just see the nipple here to the right of the inthercooler pipe opening
the other side joins the nipple and goes to the bovs just make sure you check the air filters for the bovs aswell
mate i dont want to sound rude, but have u even driven the car? you wont get the shit noise your after by simply reving it in neutral. why do you need to open you bov now? if it REALLY worries you, take it to your mechanic :/
 Share
    • Surprisingly the D6000 is only $1999, I'm waiting for the BF/CM sales, and hoping to get one cheaper. D4000 is well priced, still outperforms the 13" SVS PB-3000 and is like 1/2 the price at $1699 RRP. I do watch a fair amount of movies, and listen to EDM, jazz, symphonies, etc. so the lower notes from a subwoofer are always appreciated. The front 8" stage, just doesn't provide you with lively feeling, even though they are pretty bassy for a pair of large bookshelves. Then again, these days it's just playing Wiggles, Blippi and Ms Rachel, another reason the 3m wide cabinet exists, to hide all the audio gear behind it. They used to sit on a nice pair of stands, but as you know, they make good baby traps too.
    • Granted, which is a solid reason why I don't have one. My floorstanders are only -2 dB at 22 Hz.  So they're still working down to <20 Hz. Which is no doubt part of the reason why my receiver shits the bed! That Tonewinner would be about double the cost though, so it's not apples and apples. There aren't many AU$1300 subs (that you can buy prebuilt, I'm ignoring what can be achieved by DIYing) that compete.
    • -6dB at 22Hz isn't that great, watch the data from the D6000 from REW
    • I'll just leave this here. https://www.adelaidespeakers.com/subwoofers.html TL loading, big power. They sound awesome. This is what I would buy if I was going to try to take the bass away from my floorstanders. Just go with the 12".
    • I'll snap up some photos when I'm back home, in the office today meeting my "in the office" quota. Have 2x Teams calls scheduled in, office culture they reckon.   I've never owned a proper off the shelf sub, I've always made or modified broken ones with Jaycar plate amps and/or car subwoofer drivers. The current (and broken) subwoofer has a proper home driver in it, Dayton driver, thos one https://www.daytonaudio.com/product/118/rss265hf-4-10-reference-hf-subwoofer-4-ohm FS of 25Hz, which is low but not low enough. Yeah, I think they were brought out to the market to compete with SVS. I would love a SVS PB-3000 but they're not cheap, especially after their price hike. From reviews online, it does look like the Tonewinner D6000 would destroy and with good amount of money saved too.
