Hey guys, can anyone help me with my blitz duel sbc. Had my R34 GTT for about a year now and i just started playing with settings. while accelerating hard, at a certain point its like the engine cuts out. just woundering how to set the thing to stop it from cutting out
https://www.sau.com.au/forums/topic/295611-blitz-duel-sbc-help/
Hey mate it wont be the boost controller thats causing the problem i run a Blitz boost controller as well and it works great its impossible to set it bad really as they are very easy to play with.
Your problem will be boost cut specially if your running a standard computer. you will prolly get a happy 10psi out of it before it starts to run bad.
Have a read in the forced induction and do a search on rich and retard or boost cut and it will make things clear for you.
I recomend you contact Toshi on these forums as he tunes the standard computers and that will allow you to run more boost plus with his tune the car will go 10 times better he has done mine and it was by far the best mod i have done for power and torque increase.
  • 3 weeks later...
I had a similar problem with my R34 GTT running F-con v-pro but the stock ecu was cutting out (violent power loss and jerk forward) at just under 1 bar. The boost controller shows around 90kPa peak pressure before it starts cutting out. What I ended up doing was setting it so it wouldn't go above 90kPa, seems good now that I think about it to avoid damaging the motor. This is with an HKS EBC though, not sure how SBC works.
If you wanna run pressure higher than this than a fuel cut defender would do the trick with stock ecu or upgrade to a aftermarker computer. I wouldn't recommend going much above 1 bar with stock turbo though.
PS why is this this in 'Other Nissan Imports' section?
Edited by realor
  • 2 months later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
