I have a problem with a r32 rb20det pinging at high RPM/engine load. The car has a mines ECU, cat back exhaust, running 10psi, standard intercooler and not really maintained all that well if at all in its 130,000k life. Basically i want to have a go at fixing it before i send it off to a workshop. I have a few things i want to try and just want to know if anyone else has any idea.
1. Check spark plugs. (maybe the coil packs could be getting on)?
2. Check fuel pressure regulator for a leaky diaphram. (dont have a Guage to check fuel pressure).
3. Try moving the crank angle sensor a tiny bit anti-clock wise then drive it and see if pinging has gone. (no timing light).
4. What sort of millage do the rb20det fuel injectors generally start to have problems?
Anyone have any other ideas on some simple tests or procedures to try before the step of going to a workshop.
https://www.sau.com.au/forums/topic/29563-rb20det-pinging/
An easy test would be to swap the mines ecu with a stock ecu and see if the pinging goes away. Provided the car always runs on 98 octane this could fix your problem.
Mines ecu's are tuned for Jap high octane fuel and not 98 aussie stuff. This could be why its pinging at high revs.
https://www.sau.com.au/forums/topic/29563-rb20det-pinging/#findComment-603740
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
