Hi guys,
RB25DET throttle body a good choice for the L24E? Also can anyone estimate the bhp(at the flywheel) that these mods will give an L24E?
-72 degree regrind camshaft from SW motorsport
-RB25DET throttle body
-Exhaust (2.5 inch piping i think)
-K&N panel filter
-Maybe a set of extractors
-Also thinking about using variable resistors to modify the afm(has anyone done this before?)
I'm looking for about 160hp so I have to try and gain about 30hp up from stock. I have turbo plans for the future but just looking at N/A mods for the moment.
Yeah, gonna try and install mods that will work well with the turbo as I'm planning to turbo the L24E rather than do an engine transplant............
Why?? Because there are heaps of RB20DETs around and L24ETs are a lot fewer :)
i just bought an rb20 s13 silvia and believe me mate, it's a monster of an engine! bang for your buck and parts availability are only an advantage to you man.
Hi,
FYI. This looks similar to what you're trying to do:
http://forum.r31skylineclub.com/index.php?topic=137252.0
(R30 Datsun/Nissan Skyline turbocharged L24ET for sale)
JH
Edited by jrh001
Why?? Because there are heaps of RB20DETs around and L24ETs are a lot fewer :/
There's a reason for that Later technology,more power,cheaper and less hassles.
If you still want to stick with the old motor maybe try to find an old L20ET and graft the bits on
Cheers
The engine management is the main restriction mate.
Even if you do all that stuff hardly any real gain will be had unless there is an after market copgyback like a microtec MT4 or full ECU replacement.
If youre keen enough the RB30 gear can be used, from an R31 Skyline, it is re-mappable via nistune. lotsa mucking about though
another idea is the Delco 808 setup that runs the Holden Camira, dont laugh it is HEAPS better than the Bosch shit...
Requires heaps of fiddling and research mate....
cheapest bang for buck is bolt the turbo gear on, get a copgyback ecu, all can be done for under $1000
If i could start over, I would likely convert to RB30e very cheao and easy to work on, and can boost real good too.
Use the search feature a bit more too
What's everyone's opinion on the cam itself? Good move or no point(I'm installing it on Saturday)? I was told that the stock setup chokes the L24E pretty bad and the cam would fix that significantly(like about 15-20hp worth N/A); but I would REALLY notice the advantages when the motor is running boost.......
And rear R31 disk brakes. Also a good move?(they are going on in the next fortnight hopefully)
Sorry MAG86, I am an idiot I just tried a few alternative keywords in my search and found the answer to about 3 other questions I had. Sorry to make you repeat yourself. I am going to investigate remapping the delco further.........will let you know how it goes :happy:
Are you fitting new/re-ground rocker arms and the right size lash pads? If not, you're wasting your time and may destroy the cam in short order.
I suggest that you have a read of the L series 'bible' available here or here or here. And take it from there.
:happy:
Cams are very different from N/A to Boosted
A Turbo cam will make youre N/A run like shit, especially if youre useing the factory ECU.
Save the money. Get the turbo first!!!
If youre careful a turbo setup can be run on low boost, with the factory ECU
That would be the way to go first, then save over time for the ECU p1ggyback. Microtech MT4 can be found for $200 or so
If youre after turbo gear, search ebay, this forum, Ozdat, wreckers, engine importers.
The L28et stuff from the 280zx turbo will bolt STRAIGHT ON
Since you guys are talking about part,
I'm after another L28ET turbo manifold, the 2 on ebay will not ship internationally.
If you after some info on a turbo L24e build, this is what I did on my 240K
I started with just a EFI transplant, then my turbo install
http://www.classiczcars.com/forums/showthread.php?t=24224
My wastespark setup (EDIS)
http://www.classiczcars.com/forums/showthread.php?t=31759
my website with lots of pictures
http://noddle.110mb.com/
Nigel
Edited by noddle
I got 2 turbo manifolds here, one for me, one for sale! $300 and its yours.
Infact got a complete MR30 Hatch im wrecking (another one) if you want me to keep anything off that let me know, its getting FULLY STRIPPED tomorrow, ready to take the carcass to the crusher!
If you have the fuel pump, the fuse box (including the main plugs and foot or two of the wiring to it), the injector coil pack , and the engine efi wiring (will strip this down to what I need),
if the efi harness does not have the plug that goes to the coil pack, i'll need that as well, but I'm sure it does.
$300 for the turbo manifold is a bit more than I'm willing to pay (the one I got from the US was about $150 to my door), so I'll just keep an eye out for another one to show up on eBay.
Nigel
From hanging out on "Hybrid Z" http://forums.hybridz.org/
I came across a post talking about a N/A cam that works very well on a turbo engine, the cams is the "A" type, look on the end of the cam for the stamp (other end from the timing sprocket).
this is what I'm running on my L24 turbo engine (mine L24 is a standard N/A engine, out of a MR30, L24e)
Nigel
Edited by noddle
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
