Hi guys,
RB25DET throttle body a good choice for the L24E? Also can anyone estimate the bhp(at the flywheel) that these mods will give an L24E?
-72 degree regrind camshaft from SW motorsport
-RB25DET throttle body
-Exhaust (2.5 inch piping i think)
-K&N panel filter
-Maybe a set of extractors
-Also thinking about using variable resistors to modify the afm(has anyone done this before?)
I'm looking for about 160hp so I have to try and gain about 30hp up from stock. I have turbo plans for the future but just looking at N/A mods for the moment.
Yeah, gonna try and install mods that will work well with the turbo as I'm planning to turbo the L24E rather than do an engine transplant............
Why?? Because there are heaps of RB20DETs around and L24ETs are a lot fewer :)
i just bought an rb20 s13 silvia and believe me mate, it's a monster of an engine! bang for your buck and parts availability are only an advantage to you man.
Hi,
FYI. This looks similar to what you're trying to do:
http://forum.r31skylineclub.com/index.php?topic=137252.0
(R30 Datsun/Nissan Skyline turbocharged L24ET for sale)
JH
Edited by jrh001
Why?? Because there are heaps of RB20DETs around and L24ETs are a lot fewer :/
There's a reason for that Later technology,more power,cheaper and less hassles.
If you still want to stick with the old motor maybe try to find an old L20ET and graft the bits on
Cheers
The engine management is the main restriction mate.
Even if you do all that stuff hardly any real gain will be had unless there is an after market copgyback like a microtec MT4 or full ECU replacement.
If youre keen enough the RB30 gear can be used, from an R31 Skyline, it is re-mappable via nistune. lotsa mucking about though
another idea is the Delco 808 setup that runs the Holden Camira, dont laugh it is HEAPS better than the Bosch shit...
Requires heaps of fiddling and research mate....
cheapest bang for buck is bolt the turbo gear on, get a copgyback ecu, all can be done for under $1000
If i could start over, I would likely convert to RB30e very cheao and easy to work on, and can boost real good too.
Use the search feature a bit more too
What's everyone's opinion on the cam itself? Good move or no point(I'm installing it on Saturday)? I was told that the stock setup chokes the L24E pretty bad and the cam would fix that significantly(like about 15-20hp worth N/A); but I would REALLY notice the advantages when the motor is running boost.......
And rear R31 disk brakes. Also a good move?(they are going on in the next fortnight hopefully)
Sorry MAG86, I am an idiot I just tried a few alternative keywords in my search and found the answer to about 3 other questions I had. Sorry to make you repeat yourself. I am going to investigate remapping the delco further.........will let you know how it goes :happy:
Are you fitting new/re-ground rocker arms and the right size lash pads? If not, you're wasting your time and may destroy the cam in short order.
I suggest that you have a read of the L series 'bible' available here or here or here. And take it from there.
:happy:
Cams are very different from N/A to Boosted
A Turbo cam will make youre N/A run like shit, especially if youre useing the factory ECU.
Save the money. Get the turbo first!!!
If youre careful a turbo setup can be run on low boost, with the factory ECU
That would be the way to go first, then save over time for the ECU p1ggyback. Microtech MT4 can be found for $200 or so
If youre after turbo gear, search ebay, this forum, Ozdat, wreckers, engine importers.
The L28et stuff from the 280zx turbo will bolt STRAIGHT ON
Since you guys are talking about part,
I'm after another L28ET turbo manifold, the 2 on ebay will not ship internationally.
If you after some info on a turbo L24e build, this is what I did on my 240K
I started with just a EFI transplant, then my turbo install
http://www.classiczcars.com/forums/showthread.php?t=24224
My wastespark setup (EDIS)
http://www.classiczcars.com/forums/showthread.php?t=31759
my website with lots of pictures
http://noddle.110mb.com/
Nigel
Edited by noddle
I got 2 turbo manifolds here, one for me, one for sale! $300 and its yours.
Infact got a complete MR30 Hatch im wrecking (another one) if you want me to keep anything off that let me know, its getting FULLY STRIPPED tomorrow, ready to take the carcass to the crusher!
If you have the fuel pump, the fuse box (including the main plugs and foot or two of the wiring to it), the injector coil pack , and the engine efi wiring (will strip this down to what I need),
if the efi harness does not have the plug that goes to the coil pack, i'll need that as well, but I'm sure it does.
$300 for the turbo manifold is a bit more than I'm willing to pay (the one I got from the US was about $150 to my door), so I'll just keep an eye out for another one to show up on eBay.
Nigel
From hanging out on "Hybrid Z" http://forums.hybridz.org/
I came across a post talking about a N/A cam that works very well on a turbo engine, the cams is the "A" type, look on the end of the cam for the stamp (other end from the timing sprocket).
this is what I'm running on my L24 turbo engine (mine L24 is a standard N/A engine, out of a MR30, L24e)
Nigel
Edited by noddle
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
