This isn't really quite the right forum for this question.
Pictured is the bottom (sump removed) of an N1 block with R34 crank, when last in motion, it had no oil pressure.
how it got that way is an interesting story I can type if anyone is curious. I've posted months ago on it, but basically
it involved getting ones timing belt changed at a "tuning shop" in sydney.
My questions are the following..
* see the shiny triangles ground off the crank, what are they?
* see the oil pump cog, and snout? the snout is damaged and there is molten and solidified metal blobs in the area. The stock damper has a crack in its inner most sleeve as well, I believe that perhaps this whole thing will be difficult to remove (I'd like to look inside this pump to see the undoubtedly fractured gear) How do I remove it?
* the bores are perfect, the piston tops perfect, where will I see bearing damage (for my own curiosity)? or where to look for any other damage? remove any pair of bolts pictured and look at the crank or the bearing sleeves?
* how do you turn the crank when the block is like this on a stand or whatever
* how do I keep this in good shape if I want to wait a while. do I clean off the oil and dry out the water jacket somehow?
I said they were basic questions!
ultimately I'd be sending this away to get refreshed, but I'm kind of interested in doing some of it myself.
Anyone got a brief description of what I would do?
for example: remove oil pump and free up crank, remove crank and send it away to get checked or re-machined, Buy new pump & bearings, and re-assemble and torque the bolts correctly and with the correct tools.
the triangles you mention inthe first picture have been machined, either for clearance or balancing reasons
the 2nd and 3rd picture shows the snout has been chewed up, repair to cost of a new/2nd hand crank, well id sugest to buy a new or 2nd hand crank
turn while on engine stand use a socket (usually 27mm) on the bolt that holds the harmonic balancer onto the snout, only turn clockwise
crank is throw away. Look for a replacement but in all honesty i have bought 6 2nd cRB26 ranks over the years and all but 2 were no good.
Edited by URAS
  • 5 weeks later...
do not clean off oil if u plan on storing it for awhile. oil will prevent corrosion.
crank is rooted, get another one
take off the two nuts at the end of each conrod, pull the cap off and look at the bearings. make sure u dont mix up nuts or the conrod caps between one another. and note the way they come off becoz they only go back on one way.
im guessing they didnt do a good job with the timing belt. what workshop was it?>
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
