Item: R33 Manual Turbo, Factory Grey
Condition: Check pictures for everything
Price: If its not listed just ask and I will update with a price.
CHEAPER FOR SOME PARTS IF YOU WANT TO REMOVE THEM.
SOLD ITEMS/Smashed:
Engine
Engine loom
Gearbox
Front brakes
Front Passengers Light
Front Passengers Guard
Bonnet
front subframe- $150
steering rack- $100
Standard Suspension - $250
rear subframe + diff - $350
front seats- $100, Drivers has some wear marks
rear seat- $50
Complete Manual Conversion - $600
Tailshaft,
Clutch pedal
Brake Pedal
Gearbox Crossmember
Manual Dashcluster
Anything else you think you might need
Doors - $400 Complete for the pair
Boot + T wing- $250
seat belts- $150 the lot
fuel tank-$50
brake master cylinder/booster-100
Front Swaybar- $50
Catback exhaust - $350
Standard Wheels - $200, tyres are JUST legal
tail lights-100 for pair
speedo cluster -150
Any more parts you need just ask,
Edited by JiN_MaN
https://www.sau.com.au/forums/topic/295679-wrecking-r33/
  • Replies 54
hey mate, got any photos of the windscreen washer bottle?
also do you have the ashtray?
From memory the washer bottle is fine, but I cant remember is its got sold already or not.
Yep have the ash tray.
Take them both for $50 or if I dont have the washer bottle take the ash tray for $15
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929252
cool man, where abouts are you located?
im after a clean washer bottle in good nick - got any photos?
Car is not stored at my house so sorry no photos. Located just off anzac highway
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929301
Is that the washer bottle or the radiator overflow in the pictures on the drivers side next to the fuse box?
thats the rad overflow bottle. washer bottle sits in front of that with 2 pumps in it and a yellow cap
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929331
hey mate have u still got the stock steering wheel??
if so what condition is it in and how much if so??
Sure do mate, $130
From memory its in fairly good condition, there are 2 pics of it, check them out as best you can.
https://www.sau.com.au/forums/topic/295679-wrecking-r33/#findComment-4929403
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
