Hi All,
Just wanted to know a couple of things. The series II R33 had a couple of visual and technical changes compared to Series I - some say good, some say bad.
Anyway, my question is this: can a Series II headlight assembly fit to a Series I R33? It would appear that it is somewhat less rounded in shape and may require some cutting into the bonnet, but otherwise looks like they fit.
Any ideas?
https://www.sau.com.au/forums/topic/29570-r33-series-ii-vs-r33-series-i/
Please use the search function.
Short answer is no they do not fit.
Long answer is yes, with a lot of money, you could buy the bonnet, guards, front bar, grill and you would probably have a series II front end conversion the headlights would fit onto.
but, I have not tried it myself and I am against just believing everything i read on the internet. If i had a S2 headlight I would at least try it out then report my findings.
People said 350z 18" track rims wouldnt fit on my car and here I am driving around on them.
Um, HIPSI, did your friend change bonnet and surrounds too cause it's totally a different shape of the headlights on S2 (more square)? Also the front grille won't fit (trust me, I tried to sell my S2 grille to a guy with S1 and wouldn't fit right). Check your facts mate. :D
Wrong Sewid,
My friend over here in WA has a series 1 with series 2 headlights so it can be done. Also saw a s1 for sale in the autotrader the other week with series 2 headlights.
Get some pics. I did say I would like to see it done. Ask your mate how he did it.
The grill not fitting is the least of the problems, you could easily fiberglass up something to fit.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
