Pezhead Posted November 10, 2009 Share Posted November 10, 2009 Ok here is a question for you fellas that track your 300kw Skylines. I've been changing the oil after every track day. My GTR makes about 290 kw and has oil catch can, oil cooler, bigger radiator and runs 14-18 psi lo/hi boost depending on the type of track I'm driving. After about 10 minutes of track time my oil temp is 120 where I do a cool down and come in. Since the oil temp is so high and on boost for so long I've always felt it is a good idea to change the oil right after coming home from a track day. Always been the first thing I do. So my question - do you fellas do that too? It is getting a bit expensive cause I only use Motul 300v or Mobile1 Full Syn - so about $100 for an oil change. This on top of track fees, brakes, petrol and tyres. If this is the cost then I'd rather spend $100 preventing oil related engine failure than $$$ for a rebuild. But just want to know how you folks go? I know a lot of other guys just do normal 5k and don't change their oil after every track day. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/ Share on other sites More sharing options...
Roy Posted November 10, 2009 Share Posted November 10, 2009 I change oil every track day, but i do it the other way around. I change the oil before every track day. That way i know i have anice fresh sump and filter before every track day and oil that is in decent enough condition for pottering around on the streets, which lets face it, you can barely gas secon gear on the street so hardly stressful for the engine or the oil you are running Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4928832 Share on other sites More sharing options...
Swiper the Fox Posted November 10, 2009 Share Posted November 10, 2009 (edited) I change oil every track day, but i do it the other way around. I change the oil before every track day. That way i know i have anice fresh sump and filter before every track day and oil that is in decent enough condition for pottering around on the streets, which lets face it, you can barely gas secon gear on the street so hardly stressful for the engine or the oil you are running I change my oil every 10 minutes...about how long my engine runs at a meet. With around 20K in engine parts invested (my labour is free as i build them myself) a $250 oil change ($25 a litre plus filter) is cheap insurance. I use Motul 300V 'Le Mans' 20W60 and built the engine to run this oil weight. If it picked up a bearing and or threw a rod and i didn't do this id be always thinking whether if i had done the oil if it would have happened. Edited November 10, 2009 by DiRTgarage Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4928846 Share on other sites More sharing options...
Pezhead Posted November 10, 2009 Author Share Posted November 10, 2009 Thanks, I thought it made sense. I was surprised at a number of guys that don't. I agree that ensuring I have quality oil is key to engine life. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4928964 Share on other sites More sharing options...
fatz Posted November 10, 2009 Share Posted November 10, 2009 300v change it about every 150 laps engine still running Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929109 Share on other sites More sharing options...
MBS206 Posted November 10, 2009 Share Posted November 10, 2009 Ask Fatz about my oil changes... I do them whilst accelerating... Around the track... :banana: Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929141 Share on other sites More sharing options...
spec-V Posted November 10, 2009 Share Posted November 10, 2009 LOL! Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929151 Share on other sites More sharing options...
R31Nismoid Posted November 10, 2009 Share Posted November 10, 2009 *waits for the oil tester brigade to arrive @ the mention of super-regular changes* Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929161 Share on other sites More sharing options...
DSTROY Posted November 10, 2009 Share Posted November 10, 2009 I also change my oil before every track day, I dont want to spin a bearing like many others have. I rarely drive my car on the street so i'm not worried about having track day oil in it. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929195 Share on other sites More sharing options...
Moodles2 Posted November 10, 2009 Share Posted November 10, 2009 Oil change before track day, and then maybe do 2500km max on that oil daily driving before I change it or earlier if i've gone to another track day. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929269 Share on other sites More sharing options...
Pezhead Posted November 10, 2009 Author Share Posted November 10, 2009 Hmmm, seems to make sense doing it before but means I'm going to go through twice as much oil changing before and after. Maybe I should keep the "street" oil and put that back in after a race day but only run on the race oil for just that track day. Another expense of having a track/daily driven car. Oh well, need to take care of the beast. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929299 Share on other sites More sharing options...
Roy Posted November 10, 2009 Share Posted November 10, 2009 Dont worry about after. Seriosly, if you have done a track day on a sump of oil then i dont see a problem with running it for 4,500-5,000kms. Temp and contaminants are what hurt oil and i cant see you getting too much f either sitting in traffic or going for a drive on the street. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929316 Share on other sites More sharing options...
dazmo Posted November 10, 2009 Share Posted November 10, 2009 If you run standard or extended sump definatley change before every track day. I personally change my oil every 2-3 track days as I run a dry sump set up with water to oil cooler set up in the radiator end tank so i run around 12-15lt of oil in total inc lines and cooler and the oil temp never sees over 110 deg. Heat is what kills oil so if you can keep the heat down that will go a long way to keeping your oil healthy. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4929328 Share on other sites More sharing options...
Strik3r Posted November 11, 2009 Share Posted November 11, 2009 We used to do the oil change just before every track day when i was running the Royal Purple 10w40. When we changed to the RP41 racing oil, we were able to start using the oil for 2 track days as long as I don't do a lot of street k's between them (1000 - 1500). The oil is still seeing < 2500km's total and when we send it away to be tested all results are A-OK. We did a test where we changed the oil, did about 200k's street, then a track day, (so, <500ks total) sent the oil away to be tested. Drove the car for 1200k's street, did another track day, another few hundred k's on the street, and sent away another oil test. The only difference between the 2 samples was a tiny bit more fuel dilution (about half a percent up from 2.5 -> 3). Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4930177 Share on other sites More sharing options...
The Bogan Posted November 11, 2009 Share Posted November 11, 2009 Im new to the game but I change it before the track day, Mines a quasi daily as it only comes out if its raining or if I go for a cruise with my daughter and such. Or if its cold Or if it hot Or I have the need, the need for speed (sorry). Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4930772 Share on other sites More sharing options...
Pezhead Posted November 11, 2009 Author Share Posted November 11, 2009 I figure it is the combination of heat and lots of boost that might degrade my oil. Basically 110-120 every session for 5-6 sessions over 120k's and a fair bit of boost. I thought that the boost will create bigger compression and therefore more blowby past the rings into the block - e.g. more contaminents. Also I use a return style catch can and get a fair bit of oil/air mix com'n out of the breathers then draining back in. All good advice here folks I will probably switch to doing the oil change before the track day. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4930783 Share on other sites More sharing options...
The Bogan Posted November 11, 2009 Share Posted November 11, 2009 I get about 50 ml of hydrocarbons out of my catch can after a track day but happily no oil (as yet). Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4930794 Share on other sites More sharing options...
Wheezy Posted November 11, 2009 Share Posted November 11, 2009 I change oil every track day, but i do it the other way around. I change the oil before every track day. That way i know i have anice fresh sump and filter before every track day and oil that is in decent enough condition for pottering around on the streets, which lets face it, you can barely gas secon gear on the street so hardly stressful for the engine or the oil you are running HAHA...I'm in the same boat, I pretty much do the same. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4930875 Share on other sites More sharing options...
Duncan Posted November 21, 2009 Share Posted November 21, 2009 I change my oil every motor. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4949006 Share on other sites More sharing options...
Duncan Posted November 21, 2009 Share Posted November 21, 2009 but seriously....change it before the track day, and after if the oil got hot. otherwise like roy said run it for ages on the street. mine is track only so I change it every 3-4 days, which is normally 2-3 race meets. Link to comment https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/#findComment-4949008 Share on other sites More sharing options...
