I've personally heard of 420kw being pushed through a stock 26, but it lasted 25 minutes.
Depending on boost levels, I'd say you could safely achieve around 350-370kw on stock internals before problems would arise.
2860-5's will be lucky to get you 310kw anyway...
I'm currently doing a upgrade to the -10's (GT2871R) and aiming for around 350kw on stock internals.
Nigel.
396rwkw+ N20 at the track on 15yo stock bottom end. Raced (drag racing... mid 10's) and regular street driving for 2 years. Only reason it went bang was a bad batch of fuel and a 300m burnout...
-5's... pft! easy.
Just get it tuned properly!!!
J.
P.S.
5 years ago, there were atleast 3 stock bottomend (re-built with prepped, stock parts) cars regularly racing with more than 450rwkw. They lasted more than 25min ha ha ha ha ha haha ha haha!!!
Edited by XRATED
Depends on the use of the car.
If you are doing track days here/there - 330rwkw would be as fast as i would push it, and consequentially use smaller turbos.
Plenty have motors have not lasted the distance. Just because a select few have does not mean by any stretch that they all will.
Nigel.
Are you kidding?
-5's will, have, will do again - over 400rwkw.
The -10's (ala GT-RS) will do over 450rwkw.
If you think -5's cant make more than 310rwkw you sir need to do some serious reasearch.
the -9s (GT-SS) will do 330rwkw.
Are you kidding?
+1
Have seen -5's at over 700whp, another car at over 620whp.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
