sup guys im not sure if this is the right section to post in but anyways. i was driving my n/a 34 today and i pulled up at a intersection and the engine started idling weird and made the whole car shutter then the engine light came on which has never happened before.has this happened to anyone before? what was it?how much to fix? and should i be worried?
thanks heeps peoples. :(
https://www.sau.com.au/forums/topic/295797-wats-wrong-wif-my-beast/
most likely ur coil packs playing up if it started to sound like a rexi n ur engine light on... if u wanna confirm it get an engine diagnostic done n it will spit out the codes 4 ya... best bet is get a set of splitfires :( ... n at the same time sum plugs if they need changin
Jas is right, we have both had this problem and we both put splitfires in, there awesome but expensive (about 650 atm) and if you like there are plenty of guys that will help you install them, easiest thing to do, if your not 2 far away i'll do it for you. If you cant afford splitfires there are are others that will do the job....
update is it is at the mechanics and the mehanic cant diagnose what the problem is so i have to pick it up tommorrow morning and drive it until problem happens again then take it back to him immediately sound weird too you? do u reckon hes dodge?
I'm going to go out on a limb and say he's a moron :happy: - if he had the write equipment he will be able to plug it into your ECU via the connector under your steering wheel to the right and it will give you a code and tell you whats wrong. Also the fact that the problem is spontaneous is a symptom of coil pack failure. A Dyeing coil pack will start failing more and more and in the early stages of failure will fail when the engine is hot or at high revs (where its worked harder and harder)
Where are you located mate?
Not even the right equipment, just a paperclip!!!!! All he has to do is the consult port self diagnosis with a paperclip and read Error 21 off the check engine light :)
diagnostic.doc
Coil packs is the most common issue for R34 GT/GT-T. Get them changed. While you are at it - change the spark plugs (NGK platinum) too @around $15 each from a Nissan dealership - saves the hassle of getting to the spark plug area again later on.
Not even the right equipment, just a paperclip!!!!! All he has to do is the consult port self diagnosis with a paperclip and read Error 21 off the check engine light :P
diagnostic.doc
Well there you go, a paperclip is more useful then your mechanic :P
well today i went to see how my car is going and he still hasnt found the problem so i told him that the coils are probably rooted and he just looked at me like im an idiot he said bring it back on tuesday so im gonna find another mechanic around and iam in portmacquarie like 4hours north of sydney.
"If" he is the only mechanic in the area. Buy the ignition coils from eBay or any other shop and get him to install it.
Make sure you specifically get the coils for RB NEO engines.
Just to correct you, hes not a moron because the diagnostic thing Nissan uses wont give you a fault code unless you have the engine check light on at the time. If it comes on and you turn the car off the engine light goes away, the only way your going to get the fault code is if the light comes up and you drive to the mechanic and leave the car running while he checks it out... :(
actually, my r34 had had stored the fault code primary ignition failure 21... we tested it when the light was off then tested it again when it came on ( which was litteraly a drive around the block later, lol) just to be sure and of course it was the coils.
Edited by AYW550
lol hope he didnt think u were refering to the suspension springs as in the coils :(
how often does ur engine light come on??? like 10 mins after start up n then goes away after u turn it off n back on, or go on n off every 5 mins
also does it alwayz shudder n splutter n spit the dummy n stuff or does it come n go???
ive got a set of spare stockies u could try, wack them all in n inspect the plugs at the same time n see if the problem goes away... least then u will know 4 sure if u need 2 buy new 1ns
BUT its way easier 2 just get a diagnostic done if u can... btw u might have 2 use a GTT diagnostic
Just to correct you, hes not a moron because the diagnostic thing Nissan uses wont give you a fault code unless you have the engine check light on at the time. If it comes on and you turn the car off the engine light goes away, the only way your going to get the fault code is if the light comes up and you drive to the mechanic and leave the car running while he checks it out... :)
I'm calling him a moron for jerking this guy around, if he doesn't know whats wrong or he hasn't got the means or the know how to fix it then just suck it up and say so, don't waste ppl's time. When this happened to me i took it to my local mechanic and he had no freaking idea what was wrong and he admitted that he was unfamiliar with imports such as mine.
exactly the same as me AYW550..
Because the Tester that my mechanic uses (the guy i go to primarily specialises with imports and most commonly skylines....) can show a whole list of past codes with his tester..... and then his tester can clear all past codes so there is a 'fresh slate' so that all future codes don't get mixed up...so it didn't matter if the engine warning light was on or off
mind you he was telling me that this new tester he had cost him some crazy amount (like 10 grand or something!!) for this thing about the size of a power FC, so if your mechanic uses a different one ( and lets face it, if your not dealing with imports on a daily basis your not going to have a 10k diagnostic tool lying around) then he probably has limitations to the interaction with the ECU. but by all means correct me :P
the engine light comes on about 20 mins after driving it. when i stop it starts to shutter then the light comes on and it goes away when i turn it off and back on. i think i might just buy one of those cord things that go in my computer and if it says error code 21 i can say that it is my coils. and he probably thinks i was talking about my coils coz i just had new springs put in by him.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
