The 4WD blocks have both the hole for the 4wd and 2wd sumps, but the 2wd blocks only have the holes for the 2wd sumps. Well that is the case with the 25s at least. i have a C34 engine sitting in the shed as the moment.
EDIT!!
Just read your first post again, this isn't what you were asking.
Edited by D_Stirls
But it helps, thanks! Was hoping i could get the alloy sump off a 4wd RB20 and use a GTR larger sump welded onto it and modded to suit RWD.
Not a big deal if i have to find an AWD RB@) block as well, although i was hoping to use my current block and engine number :thumbsup:
Custom M.S. RB20 sump? It wouldnt be that hard to make up. Than you could design it around your swaybars. Would be more work converting a AWD sump and still having to enlarge that too.
High Energy Sump? They make em for RB20s?
I got an ASR (they make the sumps for High Energy) sump for my 30. The only difference that I know of between an RB20/25 sump and a 30 sump are some bits that stick up in the shallow section of the pan need to be removed for use on a 30..
All the ASR/High Energy RB sumps now have the leading edge chamfer to clear the swaybar in skylines.
Mine isn't in the car yet but I can take some photos if you want :)
Edited by bubba
Please, at the moment i am thinking to jut mod a AWD RB sump as the person doing the build has a proven custom alloy sump that has served many a track RB, both RWD/AWD
Forget it Roy, they don't fit. The 4WD sump bolts up to the wider parts of the 4WD blocks that simply isn't there in on 2WD blocks. I have been using High Energy sumps for ~20 years, never had an oil surge problem at any track, anytime, anywhere in Australia. Don't fool yourself into thinking that a winged 4WD alloy sump is lighter than the steel High Energy one, because it isn't. On the 4WD the sump adds a little (not much) rigidity to the bottom of the block, but that is mostly due to the wide bolt up spacing, which is not an option on a 2WD block. If you really just must have a shiny alloy 4WD sump and desire a miniscule amount of block strengthening then a 4WD sump adaptor would do what you want. But you will loose the block lowering advantage, which IMHO is much more worthwhile.
Cheers
Gary
Well it looks like i will be buying a new block so the build can take place whilst my car is on the street so can just as easily buy a RB20 froma GTS4 as a GTSt.
The High Energy jobbies are uber dollars and have heard/read people with mixed results, so since i know of an RB28 in an R32 GTSt running a 4wd block and modified AWD sump with similar internals to all the sumps off RB26s...it seemed the best place to start.
I think i will rather stick with a std sump then go for High Energy as I am not convinced that i need one...but will have to see what dollars are left over at the end. Plus just got new swybars and know of people having troubles with aftermarket sumps and swaybars, i know that wont be the case with the modded alloy jobbie because of said RB28 powered GTSt
Mate, get the sump from ASR instead of High Energy.
ASR make the High Enery sumps and mine cost $400 less than HE wanted for the same thing.
What bad things have you heard about them? and were they just the extended capacity sumps? or the fully baffled/gated pro-circuit sumps?
As I said above, they now make them to clear the swaybars in our cars.
If its cheap then could be. In SA? It looks as though i have already sourced an engine, (its a runner) If it falls through then a blown motor suits my needs better provided the head isnt warped from overheating or anything silly.
Will look into the ASR Sumps, though can nly find links to their products, not their website
its in melb and would be dirt cheap, just pm me if you need his details.
    • Aren't these run off of high voltage in OEM applications? Like 200+V. Or at least 48V in mild hybrids. At ~18,000 BTU ballpark nominal capacity the power draw is at what, 2.2 kW? ~185A is a pretty crazy amount of amps. At 200V it's only 11A. The 70A nominal kits with up to 100A peak draw I see for stuff like classic Porsches have pretty substantial compromises like shutting off at idle and not actually managing to keep the interior cool in hot conditions because they can only output like 6000 BTU. IMO if I had to pick what high amp draw component to retrofit to these cars I would start with the engine fan, not the AC compressor. You need an ~850-1000W brushless fan, something like this: I would love to see the data but I would bet that whatever you save by running the AC compressor in a more efficient regime with an electric motor you're probably losing to conversion losses anyways. It's not really like a clutch fan where you're losing power all the time even when it's nominally disengaged and it gets worse as it engages because the envelope tracking isn't that precise.
    • I am a volunteer marshal at the Grand Prix. As such, I get a "friend / family" ticket. It is a general admission ticket, valid for all 4 days. Anyone interested in my spare pass, please DM me. Ticket is "free, gratis and no expense".
    • agreed, the price vs gains it’s there.   unless you go china supercharger. Temu racing anyone?😂https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 😂
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
