As per other sections of the forum ...
Dyno results thread is a great idea for people to gauge mods in terms of what gains vs the cost.
Please post up any results you have, please be sure to include (where possible) a mod list, graphs, any other useful information.
As the thread goes, more results appear it will become a good resource.
No discussion please - create a separate thread for that. Results only so users do not have to troll through 3-4 pages of chat to see a result.
Cheers
Ash
https://www.sau.com.au/forums/topic/295819-r35-gtr-dyno-results/
  • 5 months later...
723Nm torque @ 3700 RPM and 518 HP @ 6100 RPM
HKS GT600 (Race)
HKS FMIC
Standard ECU
cost 34500 (inc hks trans cooler/titanium exhaust/fluids/install/tune)
Other info:
exhaust is very loud
Wheels spin in 1st/2nd/3rd traction control kicks in (even when off). Solution: COBB or F-CON
warning light on dash. O2 sensors get too hot.. Simple fix.
Hope this info is useful
Edited by druzilla32
  • Like 1
  • 1 year later...
HKS GT600 (Race)
HKS FMIC
Standard ECU
Other info:
  • 2 months later...
  • 1 year later...
HKS GT600 (Race)
HKS FMIC
Standard ECU
Other info:
This is a thread dig but is that 380kw at the wheels for 34K. If so that was pretty crap. You can get over 400 for about $4k now.
lol a bit over zealous with 400awkw with 4k..... you'll be struggling to crack 400 with oem fueling and an honest dyno
this was a long time ago
before the cobb was so widely used iirc - so tuned using fcon and splicing wires into the oem ecu
tuning was the issue, not the parts
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
